Weird Vtec problem
Old Aug 26, 2007 | 06:24 AM
h22a1_julien's Avatar
Default Weird Vtec problem
Ok so my Vtec engages no problem But its louder than it was before?!?!
and when vtec engages it seems like its not pulling like it should?
i was think there was little oil pressure?
the main thing is that its not pulling at all once on vtec
so i was just wondering if anyone of you got in the same trouble?!
thx for the help
Old Aug 26, 2007 | 06:36 AM
bluedlude's Avatar
Default Re: Weird Vtec problem (h22a1_julien)
have you checked the oil level? if thats good, check your plugs, cap and rotor
Old Aug 27, 2007 | 12:30 AM
sdr85's Avatar
Default Re: Weird Vtec problem (bluedlude)
There is also such a thing as a VTEC solenoid. Not sure where its located.
Old Aug 27, 2007 | 01:44 PM
310Integra's Avatar
Vtec solonoid is located on the rear of the head right towards the same side on the distributer. and it faces straight up. Make sure the oil is in correct level. the temp. is correct. all make sure you have no oil leaks. and that the oil pan is not dented. also might be that the solenoid can be cloged up.
Rob1242
Aug 14, 2009 04:47 PM
tigasin
Nov 14, 2008 11:58 PM
da9driver
24
Aug 25, 2005 01:00 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
01-1293
Oct 9, 2002 03:03 PM
