VSS
Old Aug 23, 2007 | 05:56 PM
trrbl1bmx's Avatar
Default VSS UPDATED... New VSS installed... PROBLEM
Ok, So I picked up a VSS from a 92-96 Prelude SI H23A1 to go with the tranny from that year. I Installed everything went smooth, bypassed the two lines on the back and just looped them together, and it still doesn't work. HOWEVER IT DOES WORK IN REVERSE.... WTF?? Does anyone have any ideas?
I just had to purchase a new tranny and it didn't come with a VSS so I need to know which VSS will work from different model trannys. I know it's an M2S4 from 92-96 H23 Prelude SI, I tried using my JDM M2A4 VSS but it's busted from when the case split. We have a pull a part close and I was thinking maybe that some accord trannys might have one that will work. Anyone have any knowledge on this. The engine is in a 93 CX Civic, but has a KMH speedo so it doesn't have to accurate, I just need vtec to work! HAHA
Modified by p00n at 6:44 PM 8/24/2007
Old Aug 23, 2007 | 06:40 PM
trrbl1bmx's Avatar
anyone?
Old Aug 24, 2007 | 04:13 AM
Speedra500's Avatar
Default Re: (p00n)
compare part numbers on slhondaparts, I believe many are interchangeable, the vss drive gear might be a little different, but I think even that is the same on some
Old Aug 24, 2007 | 03:44 PM
trrbl1bmx's Avatar
bump for some help
Old Aug 24, 2007 | 07:41 PM
trrbl1bmx's Avatar
upp
Old Aug 24, 2007 | 09:56 PM
ludeboi121's Avatar
Default Re: (p00n)
depends on the motor you are running and the ecu i believe. i have a h23 tranny swapped with my h22a, but the h23 vss doesnt work. I had to find an h22 vss in order to run right.
Old Aug 25, 2007 | 03:21 AM
trrbl1bmx's Avatar
Yeah I have the h22a and had the h22a tranny M2A4 but it came to an end. Now I have the M2S4. So you think it could be just a wrong VSS?
Old Aug 27, 2007 | 05:16 PM
trrbl1bmx's Avatar
Well this fix is gonna be expensive for the shop that supplied the tranny, because the one that I got was screwed up. The vss driver gear that is on the differential was not secure and it just moves, so the diff is turning but the gear stays in one place. However in reverse I guess it binds up and makes the speedo work.
Old Aug 27, 2007 | 05:48 PM
mgags7's Avatar
they did a differential and didn't press on the speedo gear? damn dude, where did you get that done?
Old Aug 27, 2007 | 06:08 PM
trrbl1bmx's Avatar
No... my h22a tranny exploded, they put a used tranny in for now. But since they bought it like that, they are responsible for a new tranny.
ludeDVR
Jan 29, 2020 06:10 AM
mmcd
12
May 30, 2010 11:51 PM
HyphyBB6
Nov 7, 2008 07:43 AM
crzysupra
Mar 12, 2005 12:19 PM
