vafc problem
Old Aug 25, 2007 | 08:55 PM
vteclude07's Avatar
Default vafc problem
i was cruising around with my brother and at one point i revd it up to 7k. and for some reason the CEL came on. i checked around the engine and seen the one of the plugs came off.. i started the car and the rpm gauge was all the way at zero but it was running like crap. i didnt have any problems like this before i got the vafc. right then i cut all the wires going from the ecu to the vafc. could it be that it skipped timing? any suggestions would be nice.. thanks
Old Aug 25, 2007 | 08:56 PM
vteclude07's Avatar
Default Re: vafc problem (vteclude07)
its a 97 prelude
Old Aug 25, 2007 | 09:06 PM
dagle's Avatar
pull the code first and get back to us, more info = more useful help
Old Aug 25, 2007 | 09:08 PM
vteclude07's Avatar
Default Re: vafc problem (dagle)
cylinders 1-4 all misfire
Old Aug 25, 2007 | 09:34 PM
dagle's Avatar
search for timing belt and see if theres any posts w/ problems similar to yours. i dont think it's VAFC causing this problem, do a compression check and see whats up, im thinking valves are bent at least. im by no means a pro just trying to help
Old Aug 25, 2007 | 09:47 PM
snobordboy's Avatar
Moderator
Was the VAFC wired properly?? If so, there is at least 1 wire that gets shorted to the VAFC totally, so if you cut the wires to the VAFC it wont get signal and the ecu will read wrong and the car will run wrong!
Old Aug 25, 2007 | 10:02 PM
vteclude07's Avatar
Default Re: vafc problem (snobordboi)
thats what im thinking also.. i took the car to 3 different people and everytime one of them said it wasnt hooked up right. i cut the wires and if i put them back together would the problem go away or not?
Old Aug 25, 2007 | 10:03 PM
dagle's Avatar
check the compression of your motor... if somethings wrong with the motor, VAFC is not priority right? =X
Old Aug 26, 2007 | 12:25 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteclude07 &raquo;</TD></TR><TR><TD CLASS="quote">thats what im thinking also.. i took the car to 3 different people and everytime one of them said it wasnt hooked up right. i cut the wires and if i put them back together would the problem go away or not?</TD></TR></TABLE>
if it was hooked up wrong, yes.
Old Aug 26, 2007 | 01:06 AM
THC07's Avatar
yea, cut out that VAFC and sell it, its trash. if you want a chipped ecu just ask.
realy tho, ditch the vafc.
Old Aug 26, 2007 | 05:53 AM
vteclude07's Avatar
Default Re: vafc problem (98vtec)
im hooking it up now and i want to drive 5 miles away so my friends takes it off. this is probably the last time this car had a vafc. would is cause any problems to the ecu if its hooked up wrong?
Old Aug 26, 2007 | 08:29 AM
vteclude07's Avatar
turns out it was all because of the vafc. i hooked it back up again and it started up just fine. i drove it for about 5 miles and the timing belt snapped. bent all but one valve
Old Aug 29, 2007 | 10:55 PM
crxhybrid.'s Avatar
damn mane that sucks...sorry to hear about your motor going out like that...
Old Aug 29, 2007 | 11:01 PM
dagle's Avatar
Default Re: (crxhybrid.)
cant u take that to them? i mean if its the direct cause of the damage.
Behan
Jan 27, 2004 06:54 PM
neo1z
Jun 9, 2003 07:57 AM
pzpos360
May 18, 2003 01:54 PM
Hybrid 350GT
Nov 8, 2002 02:14 PM
