differential
Old Aug 23, 2007 | 07:54 PM
vteclude07's Avatar
Default differential
what kind of differential is this? i cant get any info on the website so if anyways knows please share
http://www.horsepowerfreaks.co...pools
Old Aug 23, 2007 | 08:13 PM
Parker69's Avatar
Default Re: differential (vteclude07)
If this is what I think it is then it is something mainly used for drag racing. It in a sense melds the two axles into one, hence both wheels will turn at exactly the same rate all the time. Example: When you turn a corner the outside wheel can only turn as fast as the inside wheel so it will have to "hop" to catch up with the inside wheel. This isn't something you'd want for your daily driver at all. But if you have a car that only drives to and from the drag strip and does its main work there, then this is an option for you. This isn't a "limited slip" diff its pretty much a "no slip" differential, heh. Hope that helps!
Old Aug 23, 2007 | 08:20 PM
vteclude07's Avatar
Default Re: differential (Parker69)
wow that explains why my transmission keeps braking when i turn a corner... lol kidding just kidding. anyways that explained everything. thank you
Old Aug 24, 2007 | 11:03 AM
spoolinlude's Avatar
I live under a rock
That would be a drag spool, not intended for street use AT ALL.
Meant to go in a straight line, thats it. You wouldn't be able to drive on the street at all with that in your car, thats why you see the turbo4/hotrod/proFWD drag cars needing a huge turn around area, they have an enormous turning radius due to the locked diff.
Old Aug 24, 2007 | 11:20 AM
mgags7's Avatar
nothing like a spool in a street 240 though. mmmm lol
I knew a guy with one, every time it rained, every corner was "oh ****". lol
Old Aug 24, 2007 | 04:23 PM
I live under a rock
Default Re: (mgags7)
240 guys just weld that stock ****!
warrenf11
Sep 6, 2014 09:07 AM
facepalmOrigin
Dec 16, 2011 10:23 AM
gosu08
Apr 5, 2011 07:25 PM
TealEG!
Aug 30, 2006 07:20 AM
Ahknodd
Mar 13, 2005 08:50 AM
