VAFC setup.
Old Aug 28, 2007 | 06:19 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default VAFC setup.
My friend just bought a VTEC controller used. He needs to know how many sensors in/out to program. It is a 94 with an H22A. OBD1 (obviously).
thanks for any help.
Old Aug 28, 2007 | 06:26 PM
ludecz's Avatar
Default Re: VAFC setup. (B serious)
6in 6out.
Old Aug 28, 2007 | 07:32 PM
B serious's Avatar
Default Re: VAFC setup. (ludecz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecz &raquo;</TD></TR><TR><TD CLASS="quote">6in 6out.</TD></TR></TABLE>
cool. that's what we figured. thanks.
However, for some reason, his MAP reading is -.08 PSI at WOT. what the hell is that all about? Is that normal? I figured it would read 0 Psi.
Old Aug 28, 2007 | 07:54 PM
mgags7's Avatar
Intake, Throttle body, intake manifold, they all determine the amount of vacuum in the IM at WOT.
0 psi is optimum, his IM is just not able to keep up with the needs of the engine there.
Old Aug 28, 2007 | 08:55 PM
gotjnco's Avatar
Default Re: (mgags7)
when in idle what is the psi reading??? i wanna compare my readings to others.
Mine is at -78% psi
And when i hit vtec is around -7% psi
Old Aug 28, 2007 | 11:00 PM
B serious's Avatar
Default Re: (gotjnco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotjnco &raquo;</TD></TR><TR><TD CLASS="quote">when in idle what is the psi reading??? i wanna compare my readings to others.
Mine is at -78% psi
And when i hit vtec is around -7% psi</TD></TR></TABLE>
those readings dont make any sense. Psi cant be in a %. It's like saying your tires are at 35% psi.
When you're at idle, the vacuum should be very high. Like around -11 to -12 PSI. -14.7PSI is absolute vacuum....that's not really obtainable since there's always an open passage of air to the engine....and other reasons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Intake, Throttle body, intake manifold, they all determine the amount of vacuum in the IM at WOT.
0 psi is optimum, his IM is just not able to keep up with the needs of the engine there.</TD></TR></TABLE>
He has a newly installed SKUNK2 PRO SERIES manifold.
Maybe an electrical problem? Faulty MAP sensor? Dammit! lol.
Old Aug 29, 2007 | 05:56 AM
mgags7's Avatar
<FONT SIZE="3"><FONT COLOR="RED">OH MY GOSH!!!! A SKUNK2 PRO SERIES MANIFOLD!!!!</FONT></FONT>
I'm very unsurprised that he still has vacuum in the IM. I'll leave it at that.
Old Aug 29, 2007 | 08:04 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="3"><FONT COLOR="RED">OH MY GOSH!!!! A SKUNK2 PRO SERIES MANIFOLD!!!!</FONT></FONT>
I'm very unsurprised that he still has vacuum in the IM. I'll leave it at that.</TD></TR></TABLE>
allright. calm down.
Old Aug 29, 2007 | 08:12 AM
A Blue Lude's Avatar
Default Re: (B serious)
You should be getting as close to 0 vac as you'll ever get at WOT and low RPMs. As RPMs rise expect to see more vac as the intake system tries to keep up.
I think I remember Jdogg saying he was getting decent amounts of vac with all the 3 manifolds he tested.
Old Aug 29, 2007 | 08:19 AM
B serious's Avatar
Default Re: (A Blue Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A Blue Lude &raquo;</TD></TR><TR><TD CLASS="quote">You should be getting as close to 0 vac as you'll ever get at WOT and low RPMs. As RPMs rise expect to see more vac as the intake system tries to keep up.
I think I remember Jdogg saying he was getting decent amounts of vac with all the 3 manifolds he tested.</TD></TR></TABLE>
that's kinda weak lol.
Thanks for the help, guys.
TypeSLO
Mar 5, 2007 05:05 PM
boomersz
Feb 20, 2007 09:43 AM
b18c1srfun
Dec 8, 2005 09:08 AM
vx_civic
Oct 11, 2005 09:33 AM
RudeLude
Jan 5, 2004 03:15 PM
