I need help with a H22a into a 92 prelude.
Hello. I have the H22a swap in the car. I am wondering about the distributor. Do i use the h22a dist. with the internal coil or do I use the H23 dist. with the external coil. Also are there any other things I should be aware of with the wiring or anything? Thanks before hand for any help!!
Thanks
Alex
Thanks
Alex
Re: I need help with a H22a into a 92 prelude. (DRAGWORKS)
next time search but the h23 dizzy will work on the h22a and you just modify the external coil braket i believe. Yall Si's are prewired for vtec so not too much wiring, but there is some minor wiring to be done
Re: I need help with a H22a into a 92 prelude. (si_speed)
ok thanks. I did put the h23 dist. in it but just double checking. I still have to change oil and new coolant so we will see how it goesafter that.
Thanks
Alex
Thanks
Alex
well i got everything together started it up and it has very crappy idle and is throwing a map code. I tried a different map sensor and it is still doing the same thing. Any one have any input on where to look to correct this?
Thanks
Alex
Thanks
Alex
ionic_slim
05-24-2004 06:37 AM
