Idle problems
Old Mar 4, 2008 | 02:56 PM
bb4 jdm lude's Avatar
Default Idle problems
i have this very small idle problem... everytime i am driving down the road and put my car in neutral the car starts to idle at like 1400 rpms and slowly drops to 1000 and when i come to a complete stop the car drops down to 800 rpms after like 10 seconds. i think it may be a vacuum problem but im not sure. Does anyone have any ideas??
Old Mar 5, 2008 | 07:25 AM
gmuas's Avatar
Default Re: Idle problems (bb4 jdm lude)
have you tried any of these from this post by mgags7?
https://honda-tech.com/zerothread?id=1979500
Old Mar 5, 2008 | 09:28 AM
Maharajamd's Avatar
Sounds pretty normal to me... :/
Old Mar 6, 2008 | 05:40 AM
Default Re: (Maharajamd)
thanks appreciate the help and no this is not normal
Old Mar 6, 2008 | 06:45 AM
Maharajamd's Avatar
Car is naturally going to be in a higher rpm while driving....come to a stop its a tad high, wait while stopping goes to a perfect 700-800 rpm idle.
Whats not right?
Old Mar 6, 2008 | 06:49 AM
tommy1387's Avatar
lol.. how its doing it.. thats not normal guy.... his idle shouldnt be changing... 700-800 is fine but not if its not staying there from the start
Old Mar 10, 2008 | 06:56 AM
Default Re: (tommy1387)
tommy is exactly right why is it normal for the car to idle in between 1200 to 1500 rpm's while i am sitting still??
Old Mar 10, 2008 | 11:58 AM
4thgenaddict's Avatar
My lude does the exact same thing when its not at operating temp. I dont know what the problem is. Also when I pump my brakes the idle surges up and down. Very weird, and I've cleaned all my valves I don't know what it is. Probably just the cold weather.
Old Mar 12, 2008 | 08:57 AM
GoneToTheDarkSide's Avatar
Default Re: Idle problems (4thgenaddict)
pumping the break will make the idle change in a lot of cars... every honda I have been in does that... as far as the idle sitting around 1500 after you stop then slowly dropping, I have no idea... I have been woundering that myself because my 91 just started doin that.... it pisses me off! Im putting in a new ecu later on today to see if that may help seems how the one I have has been chiped and whored around to several cars (chip may have been instaled wrong and fried the ecu?)
Old Mar 12, 2008 | 09:25 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenaddict &raquo;</TD></TR><TR><TD CLASS="quote">My lude does the exact same thing when its not at operating temp. I dont know what the problem is. Also when I pump my brakes the idle surges up and down. Very weird, and I've cleaned all my valves I don't know what it is. Probably just the cold weather.</TD></TR></TABLE>
When your car is not at operating temp, the FITV (fast idle thermo valve) is causing it to idle higher so it will warm up faster...that is exactly what it's supposed to do. Almost all cars have something like that, it's not a problem.
Idle going up when you pump the brakes is also completely normal, most all cars will do that. It has to do with the brake booster using the engine vacuum and the one-way check valve.
How did you clean your valves?
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
ddubtoille
Aug 13, 2008 02:39 PM
EK Josh
29
Apr 11, 2005 11:05 AM
raene
Nov 7, 2002 08:21 PM
