wiring harness problem
Old Mar 13, 2008 | 10:42 AM
contractkiller's Avatar
Default wiring harness problem
Well I was gonna extend the connectors by the passenger side strut tower so I could tuck them some, well on the first connector I cut and extended all the wires and then realized there are 2 black, 2 green/black and 2 yellow/blue. So know Im stuck trying to figure out which ones go where winces theres 2 sets of each
Old Mar 13, 2008 | 12:05 PM
vlang29's Avatar
Default Re: wiring harness problem (contractkiller)
that sucks!
next time either label each one, or do them one at a time. live and learn.
Old Mar 13, 2008 | 02:11 PM
Default Re: wiring harness problem (vlang29)
so no one can help me?
Old Mar 13, 2008 | 03:33 PM
98vtec's Avatar
moderator emeritus
OBDI? OBDII?
so 6 pin connector at the shock tower?
Old Mar 13, 2008 | 06:28 PM
Default Re: wiring harness problem (98vtec)
its obd2, theres 5 connectors on the passenger side, 3 are gray, 2 of the gray are male ends, its the gray male 14 pin not the gray male 10 pin
Old Mar 13, 2008 | 06:47 PM
98vtec's Avatar
moderator emeritus
taken from the faq
https://honda-tech.com/zerothread?id=2229387
Old Mar 13, 2008 | 07:11 PM
not there
Old Mar 13, 2008 | 07:23 PM
98vtec's Avatar
moderator emeritus
Default Re: (contractkiller)
i dunno which connector you are referring to then. can you take a picture?
Old Mar 14, 2008 | 10:46 AM
Default Re: (98vtec)
I cant find my camera, right next to the cruise control thing theres five connectors, 2 are blue, 3 are gray, 2 of the gray are male, one is 10 pin the other is 14, I need the 14 pin one
Old Mar 14, 2008 | 10:59 AM
98vtec's Avatar
moderator emeritus
auto or 5 speed tranny?
my 5 speed harness has 2 blue and 2 gray, labeled like my pinout thread says.
Old Mar 15, 2008 | 10:44 PM
all the way on the left, 5 connectors.
Old Mar 16, 2008 | 08:40 AM
All-Motor-Junkie's Avatar
i think those are for you fuse box/abs connecetors, next time for future refrence irocmend some tape to label, i always label before i cut, better safe then sorry, ill take pics of mine if thatle help?
Old Mar 16, 2008 | 09:25 AM
adam62882's Avatar
Default Re: (All-Motor-Junkie)
haha... glad my F/S thread pic helps! i thought this garage floor looked familiar...
Old Mar 16, 2008 | 12:07 PM
Default Re: (adam62882)
haha yea, thanks
Old Mar 17, 2008 | 05:40 AM
alright 98vtec, where did you go, I need your help again.
Old Mar 17, 2008 | 07:35 AM
98vtec's Avatar
moderator emeritus
i dont have that 5th connector. I am guessing you have an auto tranny?
Old Mar 17, 2008 | 07:47 AM
98vtec's Avatar
moderator emeritus
ok i need you to follow the wires to the TCM and tell me the pin locations and which connector.
looking into the back of the connector (where the wires go in), the top left is 1. The pin to the direct right of that is 2. bottom right is the last pin.
connector A has 26pins, connector B has 22 pins.
once we figure out what each wire is on one side, the rest is easy.
Old Mar 17, 2008 | 10:43 AM
its a 5 speed, type sh
Old Mar 17, 2008 | 10:47 AM
98vtec's Avatar
moderator emeritus
so its ATTS related then. Follow the wires to the ATTS computer and tell me the pin locations and connectors.
Old Mar 17, 2008 | 01:10 PM
wires going into the car or on the atts connector on the engine harness
Old Mar 17, 2008 | 01:23 PM
alright i got it, it was the harness going to atts, ill get up the connectors with wire colors in a sec
Old Mar 17, 2008 | 01:36 PM
going into atts:
YELLOW/BLUE---yellow/green---yellow/red
GREEN/BLACK---blue---BLACK---black/yellow
GREEN/BLACK---brown---BLACK---red/white
blue/white---YELLOW/BLUE---green/yellow
connection at shock tower:
yellow/green---black/white---red/white
brown---BLACK---green/yellow---BLACK
YELLOW/Blue---blue---GREEN/BLACK---YELLOW/BLUE
yellow/red---blue/white---GREEN/BLACK
I did these both the the little nub the connector snabs over on the top.
ones in caps are my problems.
Old Mar 17, 2008 | 04:40 PM
come on, somebody, im so close
Old Mar 19, 2008 | 01:29 PM
where did all my help go
Old Mar 19, 2008 | 01:34 PM
98vtec's Avatar
moderator emeritus
<<< --- been busy with my motor. I'll get back to you when i can. sorry for the delay.
