Broken stud
Old Mar 12, 2008 | 07:39 PM
prelude_93vtec's Avatar
Default Broken stud
Is there any way I can get my wheel off w/out ruining it? I don't care if the rim gets a little damaged as long as I can still drive on it. They're 17x7 ADR Visions
Old Mar 16, 2008 | 01:20 PM
Default Re: Broken stud (prelude_93vtec)
Bump. Anyone ever had this problem or know how to solve it?
Old Mar 16, 2008 | 01:30 PM
vlang29's Avatar
i'm not quite sure what you mean.. how is the broken stud preventing you from removing the wheel? Do you mean you stripped the lugnut?
Old Mar 16, 2008 | 01:55 PM
Default Re: Broken stud (vlang29)
Yea. The lugnut keeps spinning in one spot and doesn't come off.
Old Mar 16, 2008 | 02:01 PM
vlang29's Avatar
aaaahh... gotcha.. so the lug is frozen to the stud, and the stud is spinning in the hub.. ouch.... air hammer/chisel?
Old Mar 16, 2008 | 03:23 PM
pentaq's Avatar
drill it out from the back of hub (?) just an idea.
Old Mar 16, 2008 | 03:47 PM
integra15's Avatar
Default Re: Broken stud (pentaq)
Wow that sucks
Maybe you could weld something to the top of the lug so you can apply outward force to make it grab to the threads on the stud better.
Old Mar 16, 2008 | 03:48 PM
I still don't know if the lug is spinning or the whole stud is. How would I get to the back of the hub?
Old Mar 16, 2008 | 08:00 PM
VTecLude1994's Avatar
I had this problem on my DD Civic. I just took a chisel and a hammer and kept hitting it til I was through the lug all the way. I did this on steelies though so I really wasn't worried. I've heard the weld something on the end of the lug trick works pretty good sometimes I would try that.
Old Mar 16, 2008 | 08:23 PM
Default Re: Broken stud (VTecLude1994)
What did you hit?
Old May 6, 2008 | 08:11 PM
Well I have thin wall lug's so it's even harder to chisel it. How much damage will the air chisel do?
Old May 7, 2008 | 04:37 AM
typeS's Avatar
Call a tire shop and ask them. It happens.
Old May 7, 2008 | 07:24 AM
Eddiebx's Avatar
waht i've done in the past is, remove all the other lug nuts, then kind of pry up the wheel a little, which applies outwards pressure on the stud, then hit it with the airgun.
it might help keep the stud still while spinning the nut off.
Old May 8, 2008 | 04:14 AM
PirateMcFred's Avatar
Maybe it's just me but I don't like banging on expensive wheel bearings with hammers and chisels. I like Eddie's suggestion.
Pirate
Old May 8, 2008 | 08:22 PM
Default Re: (Eddiebx)
I gotta try that one.
I wanna try everything before da torch!
tallblondkid
Jun 5, 2011 08:54 AM
gooberguy31
May 2, 2008 03:06 PM
Maui Built
Mar 26, 2008 09:47 PM
EKHWhat
Jan 18, 2007 05:55 PM
kyteggy
Feb 5, 2006 01:39 PM
