Motor
Old Mar 12, 2008 | 07:06 AM
OneBadVTEC's Avatar
Default Motor
I have a 98 Prelude (Base) with a H22A4, automatic. The motor is shot due to it blew a rod and the block cracked. I located a used motor from usedjapanmotor.com. The motor is coming from Japan and I was wondering what if any modification will be needed to install? Also I know there emissions are different than ours will I need to transfer parts from old motor to new used one? thanks
Old Mar 12, 2008 | 09:40 AM
AndyD's Avatar
Default Re: Motor (OneBadVTEC)
What year is the H22 you bought?
Old Mar 12, 2008 | 09:58 AM
MLBZ521's Avatar
The FAQ has info on this. Here's some threads that will help.
https://honda-tech.com/zerothread?id=1053816
https://honda-tech.com/zerothread/2084037
There's probably more, so after these threads, check the FAQ to see if there's anything else that sounds like it might be relevant to your situation.
Good luck
