engine dies while driving.... PLEASE HELP
Old Mar 11, 2008 | 05:06 PM
neo702's Avatar
Default engine dies while driving.... PLEASE HELP
hello all... I've been experiencing problems with my 98 prelude base... while driving the gauge cluster will die and the engine dies with it. All the electronics work, windows, radio, a/c, etc. the car cranks but the engine wont start. I wait anywhere from 5-30 mins then the dash lights come back on and the car starts. the timing belt, alternator, water pump have all been changed this year. Any help will be greatly appreciated!
Old Mar 11, 2008 | 05:08 PM
Acidcrakker's Avatar
Default Re: engine dies while driving.... PLEASE HELP (neo702)
Ignition Switch?
Old Mar 11, 2008 | 05:13 PM
neo702's Avatar
i just recently replaced the ignition switch... meaning the whole key assembly... would this cause the whole gauge cluster to just die... The lights on the car work and everything... the car just wont start unless the gauge cluster goes on... i checked for loose wiring behind the gauge cluster and everything is plugged in. Again, thank you for all the help....
Old Mar 11, 2008 | 05:15 PM
vlang29's Avatar
Default Re: engine dies while driving.... PLEASE HELP (Acidcrakker)
main relay?
Old Mar 11, 2008 | 05:18 PM
Default Re: engine dies while driving.... PLEASE HELP (vlang29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">main relay?</TD></TR></TABLE>
Main relay wont turn the car off. Although It does malfunction when its hot, but not while its drviing(starting the car yes), or atleast none that have popped up on these boards since Ive been here
Old Mar 12, 2008 | 11:30 AM
Lude-Lee's Avatar
Ignition Switch, Just replaced mine..Was doing the same thing. Does the RPM drop to 0 and come back up some times.
turbogrs
Aug 31, 2010 10:36 PM
jdmeg6hatchy
14
Apr 22, 2009 06:24 PM
{Sigur-Ros}
Mar 13, 2008 05:45 PM
Sack Master
Oct 22, 2004 04:49 PM
