HELP...major problems
Old Mar 8, 2008 | 06:09 AM
jamlude's Avatar
Default HELP...major problems
i got a 94 prelude si. its has a very rough idle and completly shuts off on low rpm...i have to turn the key and hold it an i hear the motor slowly bulidin up till it can sustain itslef but slowly looses rpm the shuts off again...i have changes spark plugs, spark plug wires, gas filter, and tps sensor....HHHEEELLLLLPPP!!!! PLEASE
Old Mar 8, 2008 | 06:25 AM
mgags7's Avatar
make your thread titles more descriptive in the future.
first order of business here is to do a compression test.
Old Mar 8, 2008 | 06:32 AM
FlyingDaggers's Avatar
Default Re: HELP...major problems (jamlude)
kinda sounds like mine,....
check for spark...very important...take a plug and ground them to see if you have sparks from every cylinder....if you do...move on to fuel...if ur plugs are fouled out and wet...then u got fuel and fuel injectors are okay...
do compression test like <U>mgags7</U> said...if you have all good compression...then last thing is timing.....u know the ordeal w/ timing...must be dead-on...1 tooth off and will do that....
so check those 1st....
Old Mar 8, 2008 | 06:37 AM
jamlude's Avatar
Default Re: (mgags7)
thx man ill try it
Old Mar 8, 2008 | 08:54 AM
dre2day's Avatar
Default Re: (jamlude)
How do you test your compression, i'm thinking it has to do with the vacume hoses, but what else and where do you connect? And how do you figure out the xx:x:xx ratio?
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
SmaTTeRLegion
15
Sep 2, 2013 11:28 AM
1badcrx
Jan 29, 2012 09:40 PM
Honda Hick
Feb 28, 2005 09:20 AM
jdmcx
Oct 24, 2003 10:52 AM
