egr problems
Old Mar 11, 2008 | 07:27 AM
waynecoSI's Avatar
Default egr problems
im having some confusing egr problems. I have drilled and cleaned my egr ports on the IM and changed the egr valve and im still getting code 12 and loosing power. I dont know what else i can do to fix it. its getting realy annoying. Its an h23/vtec. any suggestions are appreciated
Old Mar 11, 2008 | 08:03 AM
Acidcrakker's Avatar
Default Re: egr problems (waynecoSI)
Are you sure its the right wire plugged into the harness, from the ECU. Not to sound like a dick of course.
Old Mar 11, 2008 | 08:15 AM
BUILT93ludeSi's Avatar
Default Re: egr problems (Acidcrakker)
vacuum lines hooked up correctly? also what ECU?
Old Mar 11, 2008 | 08:49 AM
bwco's Avatar
I'd the same problem with my 95' H22, and I'm from the North which I'll have to do aircare (emission control thingy in Canada). The CEL came on after 2-3 minutes of drive and it's the EGR code 12. I went on the highway trying to give it some go, which it's totally fine. But the CEL would fail me from aircare.
So, I got home, pour in some seafoam from the pcv hose (about 1/3 pin), then wait 10 minutes. Let it suck in another 1/3 pin seafoam, wait another 15 minutes. Then drove the car to grocery shopping, no more CEL. Went through aircare and have an early pass. Amazing eh ! I can't believe it myself, but it does work magic on my H22 here in Canada. No drilling ports, no egr removal, no new gasket. Easy fix !
Old Mar 11, 2008 | 11:08 AM
mgags7's Avatar
I've never endorsed the idea of using seafoam or anything like it.
OP: Sounds like you either have a break in the wire somewhere, or you're just not getting enough lift (or the lift sensor is bad).
Maybe the replacement valve you got was used and just as dirty as your old one??? Try cleaning the valve itself.
Also, just for future reference, cleaning the EGR ports out does not fix code 12. Although a good thing to do, clogged ports have no effect on the egr valve itself.
Old Mar 11, 2008 | 12:08 PM
waynecoSI's Avatar
Default Re: (mgags7)
yea, well when i got them opened up they were totaly clogged. i cleaned the valve and yet still nothing. Im running p13. i have the right part of the harness connected to the valve....im f'n confused and annoyed. it comes and goes
Gebo
Nov 1, 2016 09:09 PM
WhiteDSM520
Jan 24, 2005 10:34 AM
blackdelslo
Jul 8, 2004 09:45 PM
DC 2
Mar 26, 2004 10:05 PM
scrubachu
Aug 21, 2002 03:32 AM
