i got a problem....
Old Mar 5, 2008 | 04:57 PM
nyturk's Avatar
Default i got a problem....
if i drive my '99 prelude for a couple hundred miles, i notice that my rear bumper starts to turn black from the exhaust....what could be the problem??
Old Mar 5, 2008 | 05:37 PM
twiztid00002's Avatar
Default Re: i got a problem.... (nyturk)
does it turn black from heat or from smoke of the exhaust
Old Mar 5, 2008 | 06:12 PM
Scrim12's Avatar
I would guess that since you say every couple hundred miles that you can clean it off. Which would mean it's smoke, not the heat. If that is the case you are probobly running extremely rich.
Old Mar 5, 2008 | 06:16 PM
dre2day's Avatar
Default Re: i got a problem.... (Scrim12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scrim12 &raquo;</TD></TR><TR><TD CLASS="quote">I would guess that since you say every couple hundred miles that you can clean it off. Which would mean it's smoke, not the heat. If that is the case you are probobly running extremely rich.</TD></TR></TABLE>
Old Mar 5, 2008 | 08:30 PM
Sampsonite987's Avatar
Default Re: i got a problem.... (dre2day)
Do you know if you have a cleared out cat? If you or someone that owned the car before you cleared it out then all that carbon is going to come straight out the tailpipe.
Old Mar 6, 2008 | 11:21 AM
copeman's Avatar
You are running rich, the black soot is unburnt fuel. Most dohc vtec engines run rich to prevent detonation. You could have searched and found the answer easily.
Old Mar 7, 2008 | 10:31 AM
nyturk's Avatar
how would i fix it if that is the case??
Old Mar 7, 2008 | 10:33 AM
nyturk's Avatar
Default Re: i got a problem.... (Sampsonite987)
no i dont know if the cat has been cleard out
Old Mar 7, 2008 | 12:36 PM
captaindammit's Avatar
if you can afford it, put a a/f ratio gauge in your car. that will tell if your runnin rich or not, and just how rich your car is running. but the black residue is most likely from the car running rich, not oil.
Old Mar 7, 2008 | 01:43 PM
98vtec's Avatar
moderator emeritus
routine maintenance needed
xintegr
Dec 13, 2006 08:52 AM
malocountry
Dec 10, 2005 08:49 AM
reza"
12
Sep 21, 2005 04:37 PM
Ateam2003
Sep 8, 2005 11:43 AM
TypeR 599
Jan 19, 2002 01:05 PM
