Fuel Pump?
Old Mar 12, 2003 | 02:57 PM
imported204's Avatar
Default Fuel Pump?
I was driving my car today and it felt a little sluggish. It seemed as if it was bogging a bit, and the rev limiter would kick in at about 6500 (i have a 93 SI with an h23 and 103,000). I parked the car, and went to start it a bit later and now it wont start. It cranks but it will not turn over, it hesitates a little after i turn the key and than just dies. I am thinking it could be a bad fuel pump, what do you guys think?
Old Mar 12, 2003 | 10:37 PM
Jago's Avatar
Default Re: Fuel Pump? (imported204)
check the distributor.
Old Mar 13, 2003 | 04:51 AM
GOTNOS's Avatar
Default Re: Fuel Pump? (Jago)
my si did that a couple times let it sit for a sec and then it will crank least thats what mine did. then it was fine it only happens every so often its weird.
Old Mar 13, 2003 | 06:30 AM
rjr162's Avatar
Default Re: Fuel Pump? (GOTNOS)
you'll want to check distributor, plugs, plug wires, fuel filter, and fuel pump. It could be any one of those causing it (I'd start with the distributor, then fuel, then spark)
Waldron Racing
Nov 26, 2013 06:45 AM
TheDonOG
Oct 7, 2013 06:08 PM
Lobster Charles
22
Mar 19, 2009 10:24 AM
marcosenid
Oct 30, 2008 04:52 PM
JolToN49
Nov 20, 2002 11:41 AM
