Check Engine Light?!?
Old Mar 17, 2003 | 03:57 PM
pimpinainteasy's Avatar
Default Check Engine Light?!?
Well i gutted my cat and now my check engine light is on. I was wondering if there was anyway i could possible get around the check engine light? Also, if I am running a loop does that mean i am running rich and losing HP? I tried to reset my ECU and it didnt do anything. Any suggestions would be great!
Thanks~Doug
P.S. I have a 2001 Electron Blue Prelude, H22A4 ,CAI. KYB's, JDM Headers, Apexi N1, and the gutted catylic converter! Here is a pic of the engine:
http://www.teamultraspeed.com/gallery/album25/louis3
Old Mar 17, 2003 | 04:01 PM
sslude's Avatar
Default Re: Check Engine Light?!? (pimpinainteasy)
it might be becuase of the ECU bieng a OBDll. maybe try and do an OBDll/OBDl conversion.
Old Mar 17, 2003 | 05:22 PM
RAB's Avatar
RAB
Default Re: Check Engine Light?!? (sslude)
I'd love to here the code you get on that check engine light. Why didn't you just buy and test pipe if you where going to gut the cat?
Old Mar 17, 2003 | 06:53 PM
Jago's Avatar
Default Re: Check Engine Light?!? (RAB)
gutting your cat is a bad thing to do since it cost's
like 700$ to replace
Old Mar 18, 2003 | 08:48 AM
Hey (sslude), what exactly is a OBDII? And what is a OBDII/OBDI conversion?
Old Mar 18, 2003 | 08:53 AM
Is there anyway to get the Check light to go out ?
Old Mar 18, 2003 | 08:57 AM
prelude22085's Avatar
OBD= On board Diagnostics.
Old Mar 18, 2003 | 09:34 AM
RAB's Avatar
RAB
You gutted your cat, there is absolutely no way to make it go off. Unless you spend $700.00 on a new one.
Old Mar 18, 2003 | 09:56 AM
So there is no way to get the check engine light to go out w/ out buying a new cat?
Old Mar 18, 2003 | 10:30 AM
satan_srv's Avatar
yeah you are losing major power, you need to either get a highflow cat or an )2 simulator.
Old Mar 18, 2003 | 10:32 AM
577HondaPrelude's Avatar
You can get rid of the light with a good O2 simulator. It will trick your ECU in thinking your cat is working. To install this you will need to splice some of your ECU wires. Also $700 for a cat is nuts!!!! You can get them for about $200 or even less. However if you don't want your cat then get a strait pipe don't gut it Or better yet get a high flow cat. Also your going to fail emissions on inspection big time, if your state has emissions that is.
http://userwww.sfsu.edu/~ecg/order.htm
[Modified by 57STS, 2:33 PM 3/18/2003]
Old Mar 18, 2003 | 10:52 AM
Default Re: Check Engine Light?!? (57STS)
Thanks guys! So how would i go about getting one of these O2 stimulators?
Old Mar 18, 2003 | 11:01 AM
satan_srv's Avatar
simulator...umm I don't have a link sorry
Old Mar 18, 2003 | 11:09 AM
Default Re: Check Engine Light?!? (satan_srv)
what acutually is this stimulator? What does it look like and how does it work?
Old Mar 18, 2003 | 11:48 AM
Chinchilla's Avatar
what about using a test pipe, If I replaced my Cat with a test pipe would I need a simulator?
Old Mar 18, 2003 | 12:28 PM
Default Re: Check Engine Light?!? (Chinchilla)
Which one should i go with: The test pipe or the O2 stimulator?
Old Mar 18, 2003 | 12:54 PM
U need a simulator if you using a strait pipe, and an OBDII ECU. It's not 1 or the other, it's both.
Old Mar 18, 2003 | 01:46 PM
So either way i am going to need the test pipe and the stimulator?!! What if i decided to go with the high flow-cat. Would i still need the stimulator or would that be all i needed?!
Old Mar 18, 2003 | 01:58 PM
phryxis's Avatar
simulator... not stimulator... if you get a test pipe, you need an o2 simulator... if you use your gutted cat, you will need an o2 simulator... if you get a high flow cat, you will not need to use an o2 simulator.
Old Mar 18, 2003 | 02:08 PM
Default Re: Check Engine Light?!? (phryxis)
Oh ok...sorry about the typo! And what does that simulator actually do and where do you find somthing like that? And (phryxis) personally what would be the best way to go?
Old Mar 18, 2003 | 02:25 PM
phryxis's Avatar
do a search on google to find out a place that will have it... just search for "o2 simulator" i found one real quick at this place: http://www.clubgpstore.com/itemview.asp?itemid=34
you would (theoretically) get the best gains with just a test pipe, but that would mean you would fail emissions, and would basically be illegal... i am going to be running a high flow cat from car sound. good luck
Old Mar 18, 2003 | 02:30 PM
Thanks (phryxis)! So what kinda of high flow cat are you looking to get? I have decided that a high flow cat would be the safest way to go
Old Mar 18, 2003 | 02:38 PM
Chinchilla's Avatar
I am under the impression that an O2 Simulator is only needed for OBDII? So I would not need one for my 93 SI if I chose to use a test pipe?
Old Mar 18, 2003 | 02:53 PM
Chinchilla's Avatar
check this out, seems pretty straight forward to me! (I'm in my second semester of electronics engineering but this is basic stuff)
http://jdmfan.com/technical/performa...sor_simulator/
Old Mar 18, 2003 | 03:02 PM
Oh thats cool, but that seems to be a lot of work if you ask me! I think i might just go with a high flow cat! This will be better and more efficient for me because i do not have a lot of time on my hands.
