Need help diagnosing problem...
Old Mar 10, 2003 | 02:31 PM
H23ludedude's Avatar
Default Need help diagnosing problem...
My car has developed a pretty nasty tick coming from the motor, i think. It speeds up as the RPM's increase. Other than that the car seems to run fine. Compression test showed this...... 200, 180, 195, 195. I changed the plugs when i did the test and the tick was still there. Can anybody help diagnose this or lead me in the right direction? Thanks.
Old Mar 10, 2003 | 02:57 PM
rjr162's Avatar
Default Re: Need help diagnosing problem... (H23ludedude)
yeap, 4 cyl valve tap. Happens over time. gap between valve and cam gets bigger, and it causes a slapping.
Old Mar 10, 2003 | 03:04 PM
Quaalude's Avatar
Default Re: Need help diagnosing problem... (rjr162)
When was the last time you adjusted your valve clearances? It's sounds like your valve clearances are out of spec.
Old Mar 10, 2003 | 03:41 PM
Default Re: Need help diagnosing problem... (Quaalude)
I adjusted the valves about 3 months ago, could it be this bad already?
4LugR
Dec 18, 2005 07:17 AM
lke2drvgsr
Apr 14, 2004 10:01 AM
FearXxConduct
Apr 1, 2004 12:48 PM
JBBNJ609
Dec 13, 2003 10:56 AM
