which injectors to run
Old Mar 12, 2003 | 03:27 PM
cccya's Avatar
Default which injectors to run
okay i have a 95 JDM H22, and i want to get some new injectors. a friend of mine said to use a set of OBDII one's and just make sure i don't hook up the injector restor box. is this true? or should a get a set RC or something.
BTW the injectors would be for N/A up to 300hp thanks
Old Mar 12, 2003 | 04:01 PM
import palace's Avatar
Default Re: which injectors to run (cccya)
stick with the same that will match the ecu you're gonna be running. if you're running a obd1 ecu then use the corresponding ecu don't jump gens....
Old Mar 12, 2003 | 05:20 PM
cccya's Avatar
Default Re: which injectors to run (import palace perf)
oaky, i have a JDM P13 now OBDI. so the OBDII injectors don't "flow" better.
I was told they do thats why i ask.
and...... soon i will be using a P28 rechiped for hondata. does anyone know if i will need an resetor box for that rechiped ECU????
Old Mar 13, 2003 | 06:03 AM
Jason kiDD's Avatar
Okay first of all. ODB I Prelude injectors are like 320cc while ODB II injectors are saturated and 290cc. So dont be fooled in thinking the ODB II ones flow more. If you still think you need to upgrade your injectors then just get some DSM ones or pay more for a set of RC's. And yes if they are of the peak/hold variety then you still have to get resistors/box in order for them to work properly..
Old Mar 13, 2003 | 06:18 AM
Firedrake's Avatar
Default Re: which injectors to run (Jason kiDD)
If it's a '95 motor and ECU that you're using (OBD1) than you already have a resistor box.....in addition, the JDM injectors flow even more than the USDM ones, so your current injectors are probably around 350cc....
Spend the money where you're really going to need it: the motor.....if you're planning on 300 whp N/A on an H22, it's going to cost you a LOT of money.....the injectors will be fine if you up the fuel pressure to 50 psi or so......
Brian
Old Mar 13, 2003 | 01:38 PM
cccya's Avatar
Default Re: which injectors to run (Firedrake)
thanks for all the help
siguy2k
Aug 19, 2012 09:20 AM
epic.fail
Mar 3, 2012 12:35 PM
dohcem1
Jan 15, 2009 11:05 PM
EKHWhat
Feb 2, 2007 05:38 PM
aaronhume
Oct 25, 2005 11:52 PM
