-HELP- Idle problem check engine light?!
Old Mar 16, 2003 | 07:25 PM
Kaizen's Avatar
Default -HELP- Idle problem check engine light?!
Ok,
Can't figure this one out. I have a turbo 96 lude H23. For some reason, my check engine light turned on and I wasn't even boosting. The check engine code is 45, but that's not even a code in the book. Anyone know what this is?
If I reset my ecu, it clears, and I can even run for a day or two and it doesn't come back even at full boost, but then it'll just come on when i'm either idling or driving normal (around 3000 rpm). I do notice that when I turn on my engine, it idles kind of high (almost 2000 rpm) and stays there until i tap the gas a couple times then it falls down to normal range (700-1000 rpm).
My best guess is that it's the missing link MAP sensor bypass valve. I checked and I have no other vacuum leaks anywhere and I have tried cleaning the missing link and tightening it extra tight. But like I said, things are fine for a day or two then it comes back.
My only other guess is maybe is it possible that I'm running too rich? Or would that not cause high idling and a check engine light?
Anyone have any ideas?
Old Mar 16, 2003 | 08:12 PM
Cottonwoodz's Avatar
Default Re: -HELP- Idle problem check engine light?! (Kaizen)
-Code 45- System Too Lean or Too Rich, malfunction in the fuel monitoring systems.
Old Mar 17, 2003 | 12:28 PM
Kaizen's Avatar
Default Re: -HELP- Idle problem check engine light?! (Cottonwoodz)
Thanks man...
That makes perfect sense w/ what's going on w/ my car.
Where did you find code 45? I have a prelude manual and it only goes up to code 43.
MinimalXistance
12
Apr 15, 2006 12:24 AM
GSRTURBO696911
Oct 21, 2005 09:55 PM
champwhiteitr
Mar 17, 2004 03:39 PM
yoshio006
Dec 17, 2002 06:18 PM
