camber kit help
Old Mar 16, 2003 | 06:06 PM
silvlude's Avatar
Default camber kit help
i have a 98 base with 18's,and the wheel shakes like bitch, besides getting it aligned what else will help. My buddy said to get a camber kit. what does a camber kit actually do and will it help ?
Old Mar 16, 2003 | 06:16 PM
Xlerate9's Avatar
Default Re: camber kit help (silvlude)
Did you lower your car?? that's usually the only time you would have camber issues. You need camber kits when your camber is out of range of the factory setting... it can be positive or negative... most of the time it's negative.
When you have negative camber your wheels kinda lean in so to speak and tuck into your wheel wells... If you were to stand behind your car... and you had negative camber... your wheels would look like this / \ The camber kit adjusts them back so they look like this again | | If you didn't lower your car you prob don't need a camber kit.
Get an alignment and have them check everything. It could be just out of alignment or you could have something loose or a number of other things. Good Luck.
Old Mar 16, 2003 | 06:36 PM
MugenPoweredLude's Avatar
Default Re: camber kit help (Xlerate9)
well wheels shaking like a bitch can be a product of:
1. Bent Rims
2. Wheels not balanced properly
3. Something else
4. Bent Rims
Old Mar 16, 2003 | 09:27 PM
jc836's Avatar
The famous warped or misaligned brake rotor could also be the cause of your problem.
Old Mar 16, 2003 | 10:25 PM
DsITR's Avatar
Default Re: camber kit help (jc836)
Good point....... does it shake under normal driving or under braking???
Old Mar 17, 2003 | 02:37 AM
silvlude's Avatar
Default Re: camber kit help (dsludefosho)
No i haven't lowered my car yet, so i guess i just need to get an alignment. thanks for your help
sublimeh215
Suspension & Brakes
Feb 10, 2009 07:34 PM
BJA86
11
Sep 2, 2007 01:00 PM
KiNG $h!t
Suspension & Brakes
Mar 7, 2005 10:52 AM
mingbling
Jul 28, 2004 02:35 AM
tr4il
Nov 23, 2001 10:14 AM
