gauge help!
Old Nov 18, 2003 | 04:17 PM
killa_lude's Avatar
Default gauge help!
i have a 93 vtec lude and i'm installing 2 gauges and it calls for the ignition switch wire...what does this wire look like? and where is it? Also whats a good dash lighting power wire to tap off of?
Old Nov 18, 2003 | 08:57 PM
jdm22vtec's Avatar
Default Re: gauge help! (killa_lude)
dont know about the ignition wire but why dont u just wire it to the gauge cluster for lighting so the gauges turn on when you have you lights on.
Old Nov 19, 2003 | 04:27 AM
Jagan'92's Avatar
Ignition wire is that black/yellow stripe wire under the steering wheel. It's inside one of the plastic looms along with some other wires, so you'll have to cut the plastic looms to look for it. just probe and make sure it goes hot when the ignition is on.
Depending on where you're mounting the guages and if they have a dimming wire, but there is a bulb that is inside the ashtray in the console, and you can tap into that wire for lights.
Old Nov 19, 2003 | 05:08 AM
killa_lude's Avatar
Default Re: gauge help! (Jagan'92)
thanks man...i will look for those!!
Old Nov 19, 2003 | 06:11 AM
dankbudz11357's Avatar
check this out for the total repair manual, you might be able to use it to answer your questions. if not at least you'll be able to use it sometime in the future.
http://www.92lude.com/
Old Nov 19, 2003 | 09:32 AM
killa_lude's Avatar
Default Re: gauge help! (dankbudz11357)
thanks man, that site is very helpful!
can someone verify where the oil sending unit is, is it directly above or directly below the oil filter?
Old Nov 19, 2003 | 12:46 PM
95PreludeSi's Avatar
it is directely below the oil filter
Old Nov 19, 2003 | 01:32 PM
killa_lude's Avatar
Default Re: gauge help! (95PreludeSi)
cool thanks man!
MilanoLude
Mar 19, 2007 03:26 PM
jeffk182
Jan 5, 2007 07:08 PM
tyflip2
Jun 14, 2004 03:08 PM
EX-T
Jul 22, 2003 08:50 PM
mrlegoman
Feb 3, 2003 04:15 PM
