Dyno run issues
Old Nov 14, 2003 | 04:20 PM
RS2500's Avatar
Default Dyno run issues
This is a run for a basically stock 1997 JDM type S Prelude only mods are mugen headers and K&N panel filter.
Max power = 127KW
A/F ratio = 12.7 – 13.6
I am concerned about the car been too lean and want to find out the possible causes of this. I noticed a lot of water spewing out the exhaust and quite a lot of black smoke at high rpm (6000rpm+). I’m currently having some issues with “possibly” my injectors between around 2500-3000rpms there is a loud ticking sound coming from the engine bay.
Any comments or help would be appreciated thanks.
This is the place I had my dyno from: http://www.torqueperformance.co.nz/home.htm
It is a rolling dyno that is all I know.
Old Nov 14, 2003 | 04:47 PM
satan_srv's Avatar
Default Re: Dyno run issues (RS2500)
could you get a graph by rpm? and SAE correction?
Anyways that's 170.3whp...sounds kinda low for a 'type-s' if you ak me, what was the temperature?
Anyways personally I don't think 13.6 is too high...look at mine I go that high quite often. I need to do a little fine tuning but it's fine
Old Nov 14, 2003 | 05:38 PM
BolivianFuego's Avatar
Default Re: Dyno run issues (satan_srv)
Yea type S motors make around 185 to 190 to the wheels stock.
Old Nov 14, 2003 | 07:52 PM
georgiajdm's Avatar
ticking=valves
black smoke and mist from exhaust= coolant and rings and/or valves leaking oil into the combustion chamber
Old Nov 14, 2003 | 08:44 PM
Cottonwoodz's Avatar
Default Re: Dyno run issues (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">ticking=valves
black smoke and mist from exhaust= coolant and rings and/or valves leaking oil into the combustion chamber</TD></TR></TABLE>
Black smoke from exhaust=Rice fuel mixture
Mist from exhaust= water vaper
White Smoke=Coolant
Anon51
May 29, 2010 06:11 AM
Greg50Lt
Honda Civic (2006 - 2015)
33
Apr 30, 2008 05:42 PM
fullblown
Dec 25, 2005 11:20 AM
IgniteTeg
Sep 19, 2002 12:37 AM
IgniteTeg
Sep 18, 2002 12:06 PM
