Quickest start
Old Nov 17, 2003 | 07:46 AM
red97prelude's Avatar
Default Quickest start
when uguys get off the line what rpm do u rev up to, to get the quickest start???? i rev mine in vtec but i was wondering if anyone knows the best wya to get off the line in the prelude????
Old Nov 17, 2003 | 07:50 AM
prelude1897's Avatar
Default Re: Quickest start (red97prelude)
When I had mine, I would rev it up between 3K-4K
Old Nov 17, 2003 | 07:58 AM
Matgallis's Avatar
Default Re: Quickest start (prelude1897)
revving that high just leaving u bouncing down the road. I rev mine between 1.5-2.5k . I get pretty good jumps on people.
Old Nov 17, 2003 | 08:18 AM
SweepeR 7's Avatar
Default Re: Quickest start (92`Legend)
it all depends on your car and tires. if you have good tires that are sticky you can launch it off in vtec. if not just around 3.5-4 should be good with just ok tires. at the track its diff. cuz you have to adjust to the track which is usually higher revs but on street its also diff. so you can't really find out whats the best untill you know what tires you have and how those tires grip in the diff. settings.
Old Nov 17, 2003 | 08:49 AM
98vtec's Avatar
moderator emeritus
you really jsut have to find what is good for ur own setup. Me, i can go to two different strips and launch two completely different ways. In Gainesville, FL i launch around 2-3k. In Holt, FL i launch around 5k. YOu just need to find out what gives you the best times. You never know. Spinning some in first could give you a better time rather than feathering the clutch.
Old Nov 17, 2003 | 09:42 AM
SKDRCR's Avatar
Default Re: Quickest start (98vtec)
Yeah man find out what is good for you
i feather the clutch around 4k
Old Nov 17, 2003 | 09:48 AM
Kidd_Stylez's Avatar
Default Re: Quickest start (SKDRCR)
i normally feather the clutch out from about 4k but when i was at the track i feathered it out from almost 5.5k and got my best time as well as 60'. Its hell on the clutch so i would let it cool between runs.
Old Nov 17, 2003 | 10:01 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Quickest start (Kidd_Stylez)
7k and just dump the clutch.
Old Nov 17, 2003 | 10:32 AM
H22A EG6's Avatar
Default Re: Quickest start (Sticky Tires)
dump it at 3500 rpm
Old Nov 17, 2003 | 10:56 AM
Default Re: Quickest start (H22A EG6)
7k, 3.5k, why not just dump it at both
Old Nov 17, 2003 | 11:25 AM
98vtec's Avatar
moderator emeritus
rev limit drop, woohooo, bye bye clutch.
stockbee
Apr 13, 2006 11:55 AM
B18CR-X
Sep 11, 2003 01:57 AM
bearboy80
Jun 8, 2003 06:22 PM
Snapspinnr
Aug 21, 2002 10:29 AM
AllMotorITR
Dec 2, 2001 02:13 PM
