need help installing an AVC-R boost controller
Old Nov 19, 2003 | 06:00 PM
ProjectLudeSiR's Avatar
Default need help installing an AVC-R boost controller
hey i have an apexi avc-r and i need to know how to install the solenoid valve. where do the vacuum lines go does anybody have a diagram
Old Nov 19, 2003 | 06:44 PM
PrecisionH23a's Avatar
Default Re: need help installing an AVC-R boost controller (ProjectLudeSiR)
The selenoid valve goes as follows:
COM - goes to the top of the wastegate
NC - Spliced in between the line coming from the compressor to the side of the wastegate.
The pressure sensor will be simply placed in any pressure source in the intake manifold. It is best to give each line that needs a pressure source its OWN pressure source instead of using a main supply for 5 or 6 sources.
Old Nov 19, 2003 | 06:47 PM
what line are u talkin about from the compressor
Old Nov 19, 2003 | 07:21 PM
Default Re: (ProjectLudeSiR)
On the compressor you will see a small threaded hole that a brass nipple fitting goes into. This is what I am talking about.
Which turbo are you running? Some turbo's do not have this but the majority of them do. You should see a line coming from the side of the compressor going to the side of the wg.
Old Nov 19, 2003 | 07:25 PM
Default Re: (GudeH23a)
i dont think mine has a hole my turbo is a Garrett GT35/GT40 what should i do
Old Nov 19, 2003 | 07:59 PM
fastludeh22's Avatar
just connect that anywhere after the turbo. ie intercooler piping, or on your intake manifold
Old Nov 19, 2003 | 08:27 PM
Default Re: (fastludeh22)
thanks dude. so thats all i need to do cool
L0co
Apr 11, 2014 05:29 PM
1320king
Jul 8, 2013 05:47 AM
kte324
Mar 7, 2010 08:19 PM
1cammerjammer
Oct 22, 2009 10:04 PM
pissedoffsol
Mar 26, 2004 07:04 PM
