4th Gen Prelude
Old Nov 19, 2003 | 03:35 PM
Tee Jay's Avatar
Default 4th Gen Prelude
Has it happen to anyone that when you're stuck in a traffic jam for 1+ hours that is literally stop and go...and your bars (the one that tells you how hot the car is) go all the way to "H" ??? If so is it normal?, because I just installed a new radiator a month or two ago.
Old Nov 19, 2003 | 03:37 PM
AndyD's Avatar
Default Re: 4th Gen Prelude (Prelude_Si)
NO!!!! That is VERY bad!!!!
The car should run with only two bars showing no matter how long you sit in traffic or let the car idle.
How long does it take to get to overheat??
Old Nov 19, 2003 | 03:38 PM
Behan's Avatar
no its not normal your fans probably aren't working. Judging by the nature of your question you should have some one else fix it.
Old Nov 19, 2003 | 03:39 PM
Tee Jay's Avatar
Default Re: 4th Gen Prelude (93preludevtec)
I turned on the heat and rolled down the windows and it went down to 2 bars in about 1 or 2 mins.
Tee Jay's Avatar
Oh and when I got to where I was going the fans were running even when I took the keys out
Old Nov 19, 2003 | 03:40 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_Si &raquo;</TD></TR><TR><TD CLASS="quote">I turned on the heat and rolled down the windows and it went down to 2 bars in about 1 or 2 mins.</TD></TR></TABLE>
You need more coolant. Have you checked your radiator reservoir??
Old Nov 19, 2003 | 03:41 PM
luder94-ChrisA's Avatar
Nope- That has never happened to me....I would look into that right away. THat is really bad for your engine Are you sure that the fans are hooked up correctly? It sounds like to me that your fans are not going on.....
Old Nov 19, 2003 | 03:42 PM
Tee Jay's Avatar
Default Re: 4th Gen Prelude (luder94si)
If they weren't than how come they were spinning on when I parked at my destination? This has never happened to me before
Old Nov 19, 2003 | 03:44 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_Si &raquo;</TD></TR><TR><TD CLASS="quote">If they weren't than how come they were spinning on when I parked at my destination? This has never happened to me before</TD></TR></TABLE>
Prelude fans always do that. You just noticed it now since you are paranoid about them not working properly.
Old Nov 19, 2003 | 03:45 PM
Tee Jay's Avatar
Default Re: 4th Gen Prelude (GudeH23a)
So this isn't normal BUMMER!!!!
Old Nov 19, 2003 | 04:41 PM
Behan's Avatar
add coolant, that is most likely you're problem if the fans are working.
Old Nov 19, 2003 | 04:43 PM
biglew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_Si &raquo;</TD></TR><TR><TD CLASS="quote">So this isn't normal BUMMER!!!!</TD></TR></TABLE>HAHA that cracked me up.
Old Nov 19, 2003 | 05:37 PM
jdm22vtec's Avatar
Default Re: 4th Gen Prelude (biglew)
wow
lol...im at a loss for words
Old Nov 19, 2003 | 05:46 PM
crj_lll's Avatar
Default Re: 4th Gen Prelude (jz)
I have had something similar happen to me. From what you have said, I would suggest checking the fans as everyone has said, then check the coolant. When you are checking the fans, make sure the fans are connected properly. If I remember properly, when the car is running, only one fan comes on to keep the engine cool. But when the car is turned off, both fans run to cool the engine down while siting still. I would check those three things and if that is not the problem, try putting your old radiator back in. Could be a bad radiator.
Old Nov 19, 2003 | 06:04 PM
jdm22vtec's Avatar
Default Re: 4th Gen Prelude (crj_lll)
i dont think anyone has mentioned the word thermostat yet
Old Nov 19, 2003 | 08:16 PM
Anhjockz's Avatar
Default Re: 4th Gen Prelude (jdm22vtec)
hahaha funny ( BUUUUUMMMMer)
well recheck everything and the fan come on when it needs too so dont trip and check the thremaste (spelling heheh) maybe a crack somewhere in the tubing i guess well have fun.....
Old Nov 19, 2003 | 08:56 PM
h22mark's Avatar
Default Re: 4th Gen Prelude (Anhjockz)
Mine goes up too 3 bars all the time and stays there. And I also replaced my radiator a few months ago. Oh yeah and I have a JDM f22b, should I worry about this or is it ok? because I've been running it like this since the swap and no problem yet.
Old Nov 19, 2003 | 10:42 PM
Kidd_Stylez's Avatar
Default Re: 4th Gen Prelude (h22mark)
this would NOT be one of those things you classify in the good category
Old Nov 20, 2003 | 04:47 AM
LudeyKrus's Avatar
make sure there's enough coolant, make sure the fans are turning on, all the electrical parts are plugged in and right, then replace the thermostat.
That's not normal......bummer!
Old Nov 20, 2003 | 05:18 AM
rkonfire's Avatar
For the second time in this thread, I will note the word *Thermostat*
Old Nov 20, 2003 | 09:43 AM
ludeDVR's Avatar
i had this also happen to me where my fans stayed on after i shut the car off. NEVER has it done this before since i've had the car for 2 years. Turns out it was my coolant level. Just make sure it's topped off. He did say that his fans work cuz they were on after he turned off the car.
Old Nov 20, 2003 | 10:53 AM
Tee Jay's Avatar
Default Re: (ludeDVR)
Thanks for all the replies...
Old Nov 20, 2003 | 10:54 AM
Tee Jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote"> did it just recently start doing this or after you put the new radiator back in. </TD></TR></TABLE>
Before I installed the new radiator it was at 3 bars constantly because I had a leak in the radiator...Now its at 2 bars before this incident in the traffic
Old Nov 20, 2003 | 02:01 PM
Xlerate9's Avatar
are you guys counting the small bar as a bar??? I think the normal operating is right in the middle... 2 big bars and the tiny one on the left. Your thermostat could be stuck shut too... might wanna check that... so check your coolant and fans first..if they seem to be ok... check your thermostat.
Old Nov 20, 2003 | 02:45 PM
SKDRCR's Avatar
Default Re: 4th Gen Prelude (Xlerate9)
i'm running fine off one fan
i would replace your thermostat
add coolant
