fan assembly
Old Nov 15, 2003 | 10:14 AM
honda4life4456's Avatar
Default fan assembly
I'm putting in a new fan assembly that I ordered to replace the radiator fan (the old one was making noises and a shop said that the motor went bad). I cant pull it out because of a coolant house going over the top, so I'm guessing I'm going to have to drain the coolant and then disconnect the hose. Is this correct or can I disconnect the hose without having to drain the coolant? I also tried to find the drain plug for the coolant and couldnt seem to find it. Any help is greatly appreciated! Thanks!
Old Nov 15, 2003 | 06:07 PM
jdm22vtec's Avatar
Default Re: fan assembly (honda4life4456)
hmmmm....the drain plug would have to be on the bottom of the radiator.
although u might be able to just pull the hose off and hold it up. Make sure u have a cup or somethin just in case it starts flowin. I dont think it should be too bad.
Old Nov 16, 2003 | 06:20 AM
Default Re: fan assembly (jdm22vtec)
thx man
CHANCELLOR12
Oct 9, 2015 07:16 AM
Kyle8595
Apr 10, 2014 09:12 AM
LT1
Sep 14, 2010 04:18 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
