performance fuel pump make a difference?
Old Jun 2, 2004 | 10:22 PM
Inextricabledrvr's Avatar
Default performance fuel pump make a difference?
will it make a difference if i get a performance one or a stock one?
if so, what do you guys recommend for a car that has the minor boltons such as: i/h/e/p/fpr
thanks
Old Jun 2, 2004 | 10:44 PM
Kal's Avatar
Kal
Default Re: performance fuel pump make a difference? (Inextricabledrvr)
won't help unless you have forced induction or nitrous. or heavy NA
Old Jun 3, 2004 | 09:09 AM
satan_srv's Avatar
Default Re: performance fuel pump make a difference? (Kal)
not on your car
Old Jun 3, 2004 | 11:04 AM
prelittlelude's Avatar
it would be stupid to buy one for you aplications. if you didn't already have the FPR thats what i would have recomended. the stock fuel pump will do just fine for the extra fuel that you need for your bolt ons
Old Jun 5, 2004 | 07:28 PM
phil2000's Avatar
Default Re: performance fuel pump make a difference? (prelittlelude)
Won't hurt though, will it? I bring it up only because I believe the pump just died on my stock 4th gen Prelude, and a Walbro 190lph is alot cheaper than a OEM replacement. I know the oem FPR should be able to compensate for any bump in pressure, but isn't it also theoretically possible to overwhelm the FPR? Just thinking out loud.
Old Jun 5, 2004 | 08:04 PM
Hawkze_2.3's Avatar
Default Re: performance fuel pump make a difference? (phil2000)
It won't hurt anything...I have a damn 255 and its fine, but it is pretty loud..
Old Jun 6, 2004 | 12:27 AM
sfjdmlud3's Avatar
just wondering what are the signs that your fuel pump is gone? One you cant hear it when starting your car? Sometimes my car starts and dies out. Wait a good 2-3 mins (longer the better) than start it up again and pray that it'll start. Sometimes takes 2-5 tries. IS it time for a new fuel pump or relay? Car is a 92. So its pretty old.
Old Jun 6, 2004 | 11:17 AM
92LudeSI's Avatar
I had this problem and it was the relay.
Old Jun 6, 2004 | 12:08 PM
phil2000's Avatar
Default Re: (92LudeSI)
later i'm planning to see if the pump's getting proper voltage (battery V when ignition is at "ON", and if it does, my pump's dead. If it's not getting voltage then obviously I have a different issue....sounds reasonable enough right.
jdmfoglights
Feb 6, 2014 06:56 AM
Psycho719
Oct 25, 2011 10:00 PM
John The G
Jun 5, 2011 09:55 PM
1sikhatch
Dec 21, 2005 08:23 AM
B16CRXT
Aug 29, 2004 11:06 PM
