high compression
Old Jun 4, 2004 | 12:11 PM
limey bastard's Avatar
Default high compression
I am running a <U>bullfrog head , intake manifold, throttlebody, cams and their reprogrammed ecu, along with type s pistons</U>, intake, headers, exhuast, and act clutch, I am having a problem with how it runs, it runs good but the bullfrog made me slower by about half a second. I ran a compression test and each cylinder was close to the same comprssion( between 248 and 255 ) The guy at the shop I go to says it is very high, but he doesn't work on to many ludes.
I have a 1994 2.2 vtec lude, I also have stock injectors, and spark. I run 93 pump gas.
IS THE COMPRESSION TO MUCH OR WHAT? AND CAN YOU THINK OF A REASON WHY I WOULD DROP HAVE A SECOND WITH ALL THE MODS UNDERLINED ABOVE.
Old Jun 4, 2004 | 12:47 PM
PirateMcFred's Avatar
Default Re: high compression (heavy22)
what is your cumbustion chamber volume and what are the cam specs?
Is it tuned? If so what is your Air/fuel ratio?
What ecu? the P13 or a chipped p28?
Do you still run a Knock sensor?
What header?
I run type-s pistons and am fine.
High compression is not necessarily an bad thing, if it knocks then it is bad.
you should be fine as long as you are not running lean.
Old Jun 4, 2004 | 02:24 PM
satan_srv's Avatar
Default Re: high compression (PirateMcFred)
go to a dyno with a wideband O2 sensor and see what the hell the problem is.
It's probably tuning. You're running a canned ecu program which probably blows
Old Jun 6, 2004 | 09:37 PM
I was going to have it tune but I wanted to get a hondata ecu first. What ecu would you say to get ? i gonna stay all motor
Old Jun 7, 2004 | 08:38 AM
If you are going to do it once then get a cheap S100. if you are going to have more modifications then get S200. But get the engine tuned quick or you could ruin your engine.
Old Jun 7, 2004 | 08:43 AM
prelittlelude's Avatar
yes if i recall with aftermarket cams and no tuning the car will lean out, but how much im not really sure. as with any mod you should get tunned. just run the highest octain in your area and then get it tuned.
If you are going to do it once then get a cheap S100. if you are going to have more modifications later then get S200. But get the engine tuned quick or you could ruin your engine.
Old Jun 7, 2004 | 10:14 AM
98TypeSH's Avatar
If you want to keep your secondaries get a p72, if not then get a p28. p28's are usally cheaper and easier to find. If you can get a good deal on a p72, go for it
Old Jun 7, 2004 | 10:23 AM
SKDRCR's Avatar
Default Re: high compression (98TypeSH)
I would just go with a p28, the p72 isn't worth it and pretty much useless
Old Jun 7, 2004 | 03:15 PM
satan_srv's Avatar
Default Re: high compression (SKDRCR)
given your already high compression you don't need to really worry about the secondaries just grab a p28 it's cheaper
Old Jun 7, 2004 | 07:59 PM
NXLude's Avatar
the aux port on an s200 can run the secondaries on a p28.
Old Jun 7, 2004 | 10:03 PM
so you think the p28 s2oo would be idle for my setup, hopefully more modes but gonna try to keep it all motor. yes\ no or should i dig up more cash and go with the p72
Old Jun 7, 2004 | 10:05 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heavy22 &raquo;</TD></TR><TR><TD CLASS="quote">so you think the p28 s2oo would be idle for my setup, hopefully more modes but gonna try to keep it all motor. yes\ no or should i dig up more cash and go with the p72</TD></TR></TABLE>
idle? idle will be fine with hondata no matter what ecu you use
Old Jun 7, 2004 | 10:42 PM
fastludeh22's Avatar
Default Re: high compression (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
idle? idle will be fine with hondata no matter what ecu you use</TD></TR></TABLE>
i think he ment ideal
Old Jun 8, 2004 | 12:11 PM
I meant to ask if it was ideal ecu for my sent up, just kinda miss printed
GoldDb7
Apr 1, 2012 05:15 PM
type B16
27
Nov 28, 2006 08:30 PM
YF-19
Dec 29, 2005 12:04 AM
Parker69
Jan 14, 2003 08:05 AM
631 Teggy
Dec 15, 2002 07:25 PM
