Changing from 1st to 2nd
Old Jun 3, 2004 | 01:45 PM
Quade's Avatar
Default Changing from 1st to 2nd
Anyone ever experienced a lag around 6,000 rpm when shifting from 1st to 2nd when you race change? I experience this whenever I change at 7,500 rpm in first gear. The rpm would fall back to 6,000 but it would just stay there like forever - weird. It doesn't seem to want to pull anymore rpm after changing to 2nd. 1st gear rushes to 8,000 rpm no problem. It seems like the engine is going on the rev limiter but yet it's not. It's a turbo H22A prelude by the way.
Old Jun 3, 2004 | 04:02 PM
Behan's Avatar
Default Re: Changing from 1st to 2nd (Quade)
possibly a slipping clutch, mine is doing the same thing and my clutch is on its last leg.
Get the car going about 35 mph, then put it in 5th gear and mash the throttle. Your rpms should increase with your speed. If it revs before you start accelarating then your clutch needs replaced.
However, if your clucth isn't slipping that bad this test may not work. Mine would exhibit the same symptoms you described but wouldn't slip using this test, until recently.
Old Jun 3, 2004 | 07:43 PM
h2point2's Avatar
Default Re: Changing from 1st to 2nd (Behan)
if the clutch is slipping just mash on it at about 5k rpms ur rpms should climb with the speedo, do this in like 2nd or 3rd but dont get pulled over :D
Old Jun 3, 2004 | 08:42 PM
94Vtecluder's Avatar
Default Re: Changing from 1st to 2nd (h2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2point2 &raquo;</TD></TR><TR><TD CLASS="quote">if the clutch is slipping just mash on it at about 5k rpms ur rpms should climb with the speedo, do this in like 2nd or 3rd but dont get pulled over :D</TD></TR></TABLE>
SickSi99
Jan 29, 2014 04:01 AM
@Diego
19
Jun 27, 2012 09:31 AM
98IntegraLSNonVtec
Jan 31, 2006 01:44 PM
Greg James
Aug 17, 2004 06:05 PM
integra0260
Sep 17, 2001 08:06 AM
