vacuum system
Old May 31, 2004 | 10:30 AM
hOndafienD 04's Avatar
Default vacuum system
there is a box with a solenoid under the intake system on top of the motor mount...it has a line the goes to the intake manifold, and another one that goes to the valve on the air box...what is this for? i have removed mine and car runs the same...can i leave it like this? thanx
Old May 31, 2004 | 10:41 AM
spoolinlude's Avatar
I live under a rock
Default Re: vacuum system (hOndafienD 04)
thats for the IAB's....... secondaries whatever...... don't take it off
Old May 31, 2004 | 10:45 AM
my secondaries are open all da time aniwaiis...i got no vacuum going to the valve...prob a puncture in the line... i doubt its for the secondaries...aren't the secondaries controlled only by the valve on the intake manifold?? this part is all the way on top of the passenger side motor mount under the intake pipe...and has a 2 wire solenoid..
Old May 31, 2004 | 12:36 PM
DW's Avatar
DW
Default Re: (hOndafienD 04)
its for the valve on the air intake resonator. if you have an after market intake its pointless because you should have removed the resonator.
David
Old May 31, 2004 | 01:36 PM
thats what i was thinking...thank you sir...
Old May 31, 2004 | 02:50 PM
mattmw88's Avatar
The IAB's are located underneath the INtake manifold (a black plastic bos with vaccuum lines and one solenoid with two wires. They control your seccondaries with a vaccum line that hooks up to the diaphraam on the drivers side of the engine somewhat close to the fuel rail/IM. Just wanted to clear up any miss info, even though you already have it figured out.
Old May 31, 2004 | 02:56 PM
thank you aniwaiis tho....always good to hear it from another persons point of view
Old May 31, 2004 | 04:04 PM
satan_srv's Avatar
just plug the line going into the IM or your idle will mess up. Once you install an aftermarket intake you can remove all that junk along with the resonator in the bumper.
Old May 31, 2004 | 04:09 PM
yeah thats all i need to do is plug up the line in the im...thanx looks a lot cleaner now...
Old May 31, 2004 | 04:16 PM
blackdelslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">thats for the IAB's....... secondaries whatever...... don't take it off</TD></TR></TABLE>
Dude if you knew anything at all youd know that the IAB vacuum box isnt mounted by the motor mount, its mounted under the intake manifold. Dont be one of those guys that gives out false info and swears they are right.
Old May 31, 2004 | 04:18 PM
I live under a rock
Default Re: (delLudeVTEC)
alright *******....... i was mistaken as to what part of the motor he was talkin about.....
Old May 31, 2004 | 04:30 PM
alright children...lets play nice...he was mistooken, maybe he didn't understand me cuz i wasn't clear...no hard feelings...
Old Jul 1, 2004 | 11:07 AM
anguish's Avatar
instead of plugging on the IM could i just route it to my BOV?
Old Jul 1, 2004 | 11:15 AM
Speedra500's Avatar
Default Re: vacuum system (anguish)
yea that would work
Old Jul 1, 2004 | 11:20 AM
anguish's Avatar
Default Re: vacuum system (Speedra500)
there is some kind of valve or sensor between the air box and my IM.. wtf is that? should i just plug it and run the line straight from IM to BOV or run my BOV from the sensor/valve/thing?
Accordin2me
Aug 5, 2010 03:02 PM
sony224422
Jul 21, 2006 02:43 PM
Steve-o
Jan 29, 2006 05:45 PM
93sleeper
Mar 22, 2005 01:50 PM
koco
Feb 16, 2003 02:37 PM
