blown H23
blown H23
After 215000 miles of abuse my H23 finally cracked the crank. I am in need of an new engine and just figured I would upgrade to the H22. I was wondering if all you guys that have done any motor swaps know of a good place to get an engine. Please list any problems (if any) you had after installing the engine and how long it has been in you car. My concern about getting a jdm engine is that there is really no warranty on them. Any information you could provide would be much appreciated. Thanks in advance!!!
Re: blown H23 (CivicSiDriver02)
The best advice anyone is going to give you, before they tell you to search past threads is to do your homework. Learn about what you are getting into. This is not something to be taken lightly. The H22 is a strong motor and will last a long while depending on the conditions. My only advice is to stay away from Osaka at any cost.
Search past threads, and good luck.
-RG
-RG
you may whant to hit up [ams mike] he can get you a complet swap for about $2700 comes with everything,the only thing you need is a wire harness. my buddy dxtrix has a h22 wire harness for your car.you may whant to hit both of them up.
they will hook you up.
