ECU Codes
Old Jun 2, 2004 | 07:11 AM
simon98h22's Avatar
Default ECU Codes
Just installed a 95 H22A, throwing 3 codes so far, anyone have a reference or know what they are ?
20, 21, and 36
Thanks!
Si
Old Jun 2, 2004 | 08:05 AM
prelittlelude's Avatar
Default Re: ECU Codes (simon98h22)
20 is electric load detector
21 is vtec solinoid
and i have no idea about 36, let me look into that
simon98h22's Avatar
Default Re: ECU Codes (prelittlelude)
Awesome thank you
Old Jun 2, 2004 | 08:13 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">20 is electric load detector
21 is vtec solinoid
and i have no idea about 36, let me look into that</TD></TR></TABLE>
I take the code 36 part then
code 36 if for the traction control option found on JDM vehicle. It is a ghost code and does not affect drive ability of the vichile. It only shows up when you jump for codes. If you want more info just do a search, there are a ton of threads on that code.
Old Jun 2, 2004 | 08:26 AM
simon98h22's Avatar
Default Re: ECU Codes (CHK4TIX)
Awesome! Thanks guys!!! One way of finding out my motor really is JDM
Old Jun 2, 2004 | 08:31 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simon98h22 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome! Thanks guys!!! One way of finding out my motor really is JDM </TD></TR></TABLE>
well, actually that only the way to tell that your P13 is JDM, the way you tell your engine is JDM is if it has H22A stamped on the block
Old Jun 2, 2004 | 08:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">
code 36 if for the traction control option found on JDM vehicle. It is a ghost code and does not affect drive ability of the vichile. It only shows up when you jump for codes. If you want more info just do a search, there are a ton of threads on that code.</TD></TR></TABLE>
man i NEVER knew this.. wow thats cool, what kind of traction control did the jdm preludes have?
Old Jun 2, 2004 | 08:57 AM
simon98h22's Avatar
well, actually that only the way to tell that your P13 is JDM, the way you tell your engine is JDM is if it has H22A stamped on the block</TD></TR></TABLE>
Very true ... motor is stamped H22A so it's all good.
Old Jun 2, 2004 | 08:59 AM
simon98h22's Avatar
man i NEVER knew this.. wow thats cool, what kind of traction control did the jdm preludes have?</TD></TR></TABLE>
Just curious, the fact that this motor came with an LSD tranny have anything to do with code 36 ? Or is this something found on all H22A JDM ECU?
Old Jun 2, 2004 | 09:55 AM
CHK4TIX's Avatar
Just curious, the fact that this motor came with an LSD tranny have anything to do with code 36 ? Or is this something found on all H22A JDM ECU?</TD></TR></TABLE>
no, your ecu has 4 plugs unlike the normal p13 that only has 3. the forth plug actually goes off the the computer added traction control which i believe is on accord (dont quote me on the accord part)
Old Jun 2, 2004 | 06:37 PM
Adam.'s Avatar
I have an M2B4 (JDM LSD) tranny and I never received Code 36. I ran the JDM P13 for nearly a month and only got an EGR, even when jumping the service connector.
EDIT: That is, if you have a three plug ECU.
Old Jun 2, 2004 | 07:20 PM
CHK4TIX's Avatar
Default Re: ECU Codes (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]I have an M2B4 (JDM LSD) tranny and I never received Code 36. I ran the JDM P13 for nearly a month and only got an EGR, even when jumping the service connector.
EDIT: That is, if you have a three plug ECU. </TD></TR></TABLE>
thats correct you only get the code 36 if you have the 4 plug p13, it was not an option for the 3 plug model
Mad Hatter
Nov 14, 2005 02:50 PM
dreams190
Apr 1, 2005 07:03 AM
hondaadnoh
Jan 6, 2004 02:44 AM
nocturnalJDMH22A
Oct 15, 2003 05:43 AM
boost killz
Sep 7, 2001 10:59 AM
