cold start....will not start!
Old Jul 5, 2004 | 09:14 PM
sleepy_vtec's Avatar
Default cold start....will not start!
My girlfriends accord ( and i posting this here because we prelude owners are obviously more intellegeant when it comes to cars because we do not have accords!) will not crank sometimes. It seems to be when it is cold outside. I know when accords will not crank because of it being hot, it is the main relay inside the car...most of the time. I have been thinking of the possibility of the ignitor going back, because the f22's are internal coil, well atleast in 4th gen accords. Has anyone ran across this problem?
Old Jul 5, 2004 | 09:45 PM
LUDERH22's Avatar
could be that its the starter solenoid.
Old Jul 6, 2004 | 06:54 PM
FASTER88PRELUDE's Avatar
Default Re: cold start....will not start! (sleepy_vtec)
WELL TRY TESTING THE BATTERY OR CALLING THE PARTS HOUSE TO SEE IF THE BARTTERY IS THE RIGHT ONE FOR YOUR CAR. IF U DON'T HAVE THE RIGHT CCA THEN THE BATTERY WELL DIE AND THE CAR WILL NOT START. AND ALSO TAKE THE STARTER OUT AND GET IT TEST AS WELL!
Old Jul 10, 2004 | 08:35 PM
Default Re: cold start....will not start! (FASTER88PRELUDE)
ok, i didnt get much help with this one. The starter is fine, the battery is fine. It cranks fine, but will not turn over if it is cold.....anyone?
Old Jul 10, 2004 | 08:51 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FASTER88PRELUDE &raquo;</TD></TR><TR><TD CLASS="quote"> WELL TRY TESTING THE BATTERY OR CALLING THE PARTS HOUSE TO SEE IF THE BARTTERY IS THE RIGHT ONE FOR YOUR CAR. IF U DON'T HAVE THE RIGHT CCA THEN THE BATTERY WELL DIE AND THE CAR WILL NOT START. AND ALSO TAKE THE STARTER OUT AND GET IT TEST AS WELL!</TD></TR></TABLE>
Caps make my eyes bleed
Old Jul 10, 2004 | 08:52 PM
sharkcohen's Avatar
Check the spark plugs, they may need replacing.
Old Jul 12, 2004 | 10:02 PM
Default Re: cold start....will not start! (sharkcohen)
plugs are brand new. I was thinking the distributor. Internal coil or maybe the ignitor. Anyone?
poprocksncoke
Jan 28, 2017 04:56 AM
Matt S.
Jan 31, 2016 11:24 AM
strike1nc
Dec 9, 2004 03:46 AM
Accord15
Feb 20, 2003 02:16 PM
ahcjar103
Dec 9, 2001 11:37 PM
