couple problems
Old Jul 4, 2004 | 07:26 PM
95luda's Avatar
Default couple problems
i have a 95 prelude S, and i needed to change the oil this week, but as i unloosen the bolt, it just keeps on spinning. wtf?! the bolt refuses to come out. only thing i can think of is that i might have a stripped oil pan...ne know what the problem is?
Another problem i have, is that for some reason it wont let me spray winshield washer fluid. Ne one got any thoughts on that? and do i take it in b/c of airbags? dont kno if that will be a problem takin off the steering column.
Thanks
Old Jul 4, 2004 | 07:54 PM
crdcz03's Avatar
Fortune Cookie Member
Default Re: couple problems (95luda)
your oil pan is prolly stripped...
and i dunno about your other problems... except to say check your windshield washer fluid level but you probably (hopefully) already did that
Old Jul 4, 2004 | 10:33 PM
ludedudeh23's Avatar
yeah ya pan striped id pull the bolt out and grain it then seal it in there or make new threads and windshield fluid i would check to make sure that the hoses are hooked up under the hood and air bags yeah it wont be a prollem to take the steering colum off it wont explot out.
Old Jul 5, 2004 | 05:06 AM
matix's Avatar
did the same thing to my oil pan bolt. Gotta get pressure on it and it will back out. Then goto napa auto parts and get a oversized oil pan bolt. It bolts in and has another bolt on that bolt so u never actually have to back out the big bolt that is oversized.
Old Jul 5, 2004 | 05:41 AM
mdjplay's Avatar
Get a flat-head screwdriver between the bolt-head and the oil pan and pry outward as you back out the bolt.
Check your fuse to your windshield washer... does the motor make noise when you try to use it?
Old Jul 5, 2004 | 09:24 AM
matix's Avatar
Default Re: (mdjplay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdjplay &raquo;</TD></TR><TR><TD CLASS="quote">Get a flat-head screwdriver between the bolt-head and the oil pan and pry outward as you back out the bolt.
Check your fuse to your windshield washer... does the motor make noise when you try to use it?</TD></TR></TABLE>
Exactly thats how i got mine off.then get the oversized piggy back bolt.
sleeperhonda
10
Aug 20, 2013 08:18 AM
kaychi
Jul 9, 2008 12:10 PM
ombl4
May 10, 2007 01:42 PM
MechEng
Oct 21, 2005 12:14 PM
y0itzflip
Oct 11, 2005 05:12 AM
