Ground Control Install Issues
Old Jun 30, 2004 | 03:22 PM
Jeff99Base's Avatar
Default Ground Control Install Issues
I ran into a little bit of a problem installing my Ground Controls that I was hoping someone could help me out with. I am trying to slip the threaded sleave over the shock, and am having problems. The instructions say to slip the cut rubber isolator over the shock then slip the sleave over that. I have found that the sleave barely fits over the shock, let alone the sleave and shock.
I think that if I beat on it some it will slide over, I was just wondering if this was typical. They are going on a 5th Gen with Tokico Illumina shocks.
Thanks,
-Jeff
Old Jun 30, 2004 | 06:05 PM
PhazedSI's Avatar
Use the o rings provided in the GC kit. I beleive the sleeves are only meant for stock struts. Any aftermarket struts i've seen used w/ the GC kit have been too big to use the sleeves.
lawlsss
Nov 30, 2009 11:47 PM
AutoXer
Suspension & Brakes
Apr 19, 2005 04:29 PM
GroundZer0
Mar 30, 2004 06:28 PM
pucho
Sep 21, 2002 09:08 PM
