DOHC
Old Aug 30, 2004 | 12:02 AM
billyvalo's Avatar
Default DOHC
what does DOHC mean..and whats the diff between DOHC VTEC and just VTEC
Old Aug 30, 2004 | 12:08 AM
Wiseguy619's Avatar
Default Re: DOHC (billyvalo)
DOHC-Dual Over Head Cam
Old Aug 30, 2004 | 12:24 AM
Hawkze_2.3's Avatar
DOHC VTEC is a VTEC engine with 2 overhead cams. VTEC is a system where the engine uses 2 cam profiles at different times. There are SOHC and DOHC VTEC engines.....
Old Aug 30, 2004 | 01:04 AM
Turck's Avatar
http://auto.howstuffworks.com/question229.htm
Old Aug 30, 2004 | 02:36 AM
billyvalo's Avatar
thanks
Old Aug 30, 2004 | 08:04 AM
SKDRCR's Avatar
Default Re: (billyvalo)
want some knowledge billyvalo?
read up on this
https://honda-tech.com/zerothread?id=689805
Old Aug 30, 2004 | 09:34 AM
kablamo's Avatar
DOHC = Dual OverHead Cam
an engine with DOHC VTEC has VTEC (Variable Valve Timing) on both intake and exhaust valves.
a "plain" VTEC engine is SOHC, Single OverHead Cam, and VTEC only works on the intake side, limiting the power gains. On an SOHC VTEC engine VTEC can only work on the intake side because without making the engine dramatically more complicated, there is only enough room on the Single Cam for extra cam lobe profiles for the intake valves.
SisterFister
59
Jan 15, 2011 08:10 AM
.God.
14
Apr 16, 2006 05:10 PM
majinx4
Apr 12, 2006 11:24 AM
boy_honda
May 8, 2004 08:30 PM
uranazo
39
Nov 11, 2003 04:17 AM
