cams
Old Aug 27, 2004 | 09:48 AM
johnbrooke86's Avatar
Default cams
I have and old head left over from the swap. Will the cams bolt right on to the old head or do I need to do something to them first.
Old Aug 27, 2004 | 09:58 AM
Hawkze_2.3's Avatar
Default Re: cams (johnbrooke86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnbrooke86 &raquo;</TD></TR><TR><TD CLASS="quote">I have and old head left over from the swap. Will the cams bolt right on to the old head or do I need to do something to them first. </TD></TR></TABLE>
WHAT??? What swap? What head? What cams???????????????????????
Old Aug 27, 2004 | 10:21 AM
Default Re: cams (Hawkze_2.3)
I bough A 91 SI with a motor that had slipped a sleave. Put a used motor a wile ago. Broke the timeing belt last weekend.Put a new one in and I'm getting no compresion on the #1 cylinder. So that means bent valves. I still have the head of the old engine so I am going to take it and have it checked. If its good ,can I take the 2 cams off the old head and put them on the other head with no prob or is there something that has to be done first?
Old Aug 27, 2004 | 10:23 AM
Hawkze_2.3's Avatar
If the cams aren't damaged, I don't see why not...as long as they're both H23s.
Old Aug 27, 2004 | 10:25 AM
Thay look good and both same. I just didnt know if anything needed to be replaced or what not.
Old Aug 27, 2004 | 10:33 AM
Hawkze_2.3's Avatar
OK, well, cam seals are good to replace..also timing belt and all the gaskets that you can find...
Old Aug 27, 2004 | 10:36 AM
LudeyKrus's Avatar
I wold plastigage them just to be sure, to check all the clearances.
psegs80
Oct 31, 2009 11:25 AM
xstalkrx
May 16, 2003 12:24 AM
Red99CivicSi
Mar 2, 2003 07:32 AM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
