Can Someone work this check engine code out please??
Old Aug 26, 2004 | 02:49 AM
shabasoft's Avatar
Default Can Someone work this check engine code out please??
hi I have tested the service connector as my check engine light comes on.
the blinks i got its as follows:
3 short
1 long
7 short
2 long
1 short
does this mean a code 41?
If so what does that mean and what could be wrong? how di i fix it?
thanks in advance.
Old Aug 26, 2004 | 03:44 AM
CHK4TIX's Avatar
Default Re: Can Someone work this check engine code out please?? (shabasoft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shabasoft &raquo;</TD></TR><TR><TD CLASS="quote">hi I have tested the service connector as my check engine light comes on.
3 short
1 long
7 short
2 long
1 short
thanks in advance.</TD></TR></TABLE>
I believe you have code 3 or 30, 17, 21 but Its been a while since i had to check codes.
Old Aug 26, 2004 | 04:16 AM
delguiner's Avatar
Default Re: Can Someone work this check engine code out please?? (CHK4TIX)
i concur codes 3,17,21
Old Aug 26, 2004 | 06:12 AM
Jagan'92's Avatar
http://www.92lude.com/self_diagnostic_codes.htm
I'm not seeing a code 21 on this page, but it may be in the full blown helm's manual chart. Maybe this will get you started though.
Old Aug 26, 2004 | 08:17 AM
spnbb2
Guest
Posts: n/a
3-map
17-VSS-speed sensor
21-vtec spool solenoid valve
Old Aug 26, 2004 | 08:20 AM
98TypeSH's Avatar
Default Re: (SPN BB2)
and i thought just throwing 1 code was bad, you got 3 pretty harsh ones goin there. Good luck on finding the problem. If you need to know how to replace anything post back in here.
Old Aug 26, 2004 | 09:04 AM
kellyk75's Avatar
Default Re: (98TypeSH)
Oooohhhhh..... the 31721 code....... that is the universal code for "Time to buy a new car".
J/K.
Sounds like you have some work ahead of you. How does the car drive? Maybe instead of three probs.... you have 1. The ECU.
Old Aug 26, 2004 | 01:01 PM
shabasoft's Avatar
Default Re: (kellyk75)
the car drives fine that the thing. I have reset the ecu, but still have these issues.
any hep on solving them will be good.
tf87
Mar 7, 2019 04:00 PM
Delano5050
Aug 5, 2008 09:12 AM
92TEGsrSC
Oct 17, 2003 02:42 PM
I wanna be Steve!
May 2, 2003 11:09 AM
Hatchy-Ownzjo0
Aug 31, 2002 06:56 PM
