ABS light question
Old Aug 30, 2004 | 11:31 AM
sushib01's Avatar
Default ABS light question
abs fuse inside my car is taken out. the abs light comes on. in turn would it make the brake lamp light turn on?
Old Aug 30, 2004 | 03:29 PM
sushib01's Avatar
Default Re: ABS light question (sushib01)
help...please?
Old Aug 30, 2004 | 03:32 PM
Skidtron89's Avatar
I'll answer this even though it is poorly worded. First off put your ABS fuse back in there is no advantage to having it disabled. Next there are to "brake warning" lights if this is a 4th gen anyways and maybe a 5th as well can't remember right now. There is one that warns you if a taillight/ brake light is out. This light rarely lies and you probably have a tail light /brake light out. Have someone push the pedal and see if all three work. Next if you mean could the brake warning light that comes on when you set the emergency brake come on during a turn then: Check the brake fluid level it is probably dangerously low. There is a sensor in the brake fluid resivour on top of the brake master cylinder. Do yourself a favor and check the clutch fluid and ABS fluid as well top off where needed. Further mor you might have a bad pin switch on the e-brake its self which also triggers teh above mentioned light I have only seen it twice ever on many many Hondas but it could be making bad contact when the e-brake is released or in the down position. Check some of this and get back maybe word your post a little better and more people would help you as well. Good luck!
Old Aug 30, 2004 | 03:40 PM
kellyk75's Avatar
no, should just be ABS. If it is a 5th gen and the brake light comes on, 9/10 times it is low fluid even though it looks full. Top it to the max
Old Aug 30, 2004 | 03:43 PM
sushib01's Avatar
Default Re: ABS light question (Skidtron89)
the brake lights work perfectly fine. clutch, brake, abs fluid are fine too. thinking about it, when i step on the clutch and brake pedals at the same time, then the "brake lamp" light comes on.
vtecdc4
Jul 15, 2010 04:46 PM
supermotothud
Nov 10, 2008 04:09 PM
daddy
Honda Civic (2001 - 2005)
May 29, 2007 09:02 AM
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
faiz_23
May 26, 2002 08:22 PM
