CD player needs code after battery reset, any suggestions?
Old Aug 30, 2004 | 10:17 AM
thelarkascend1ng's Avatar
Default CD player needs code after battery reset, any suggestions?
alright so this ties in with the ABS thing, sort of, but it's really a simple and annoying fix. after resetting the ECU to see if that helped turn off the ABS light, the CD player needs a security code. i could try calling the original owner and see if he or his wife knows it, but even if they didn't, i wouldn't know how to input it. any help? will i have to honda dealership this one? thanks.
Old Aug 30, 2004 | 10:36 AM
ItalynStylion's Avatar
Default Re: CD player needs code after battery reset, any suggestions? (thelarkascend1ng)
Ok, in your owners manual there should be a section on the radio code.
Mine had a little credit card shaped paper that had the code on it.
Not sure on the rest of the details but it fully explains it in the manual.
Old Aug 30, 2004 | 10:49 AM
Default Re: CD player needs code after battery reset, any suggestions? (ItalynStylion)
i feel like a tool saying this but the car didn't come with the manual.
Old Aug 30, 2004 | 10:54 AM
preludeez's Avatar
it's a number code that is inserted by using the preset numbers on the radio when it is on...find the code, turn on the radio, punch in code...
btw, since you dont have the manual, if you have the "red key" - do not stick it in the ignition
Old Aug 30, 2004 | 11:06 AM
revlimitx04's Avatar
Default Re: CD player needs code after battery reset, any suggestions? (preludeez)
Sounds like your screwed, happend to me and I called old owner, he knew it off the top of his head, then wrote it in the front of the manual, (it didnt have the code in it)
If i were you Id call the person who owned the car before you, if they dont know it, time for an Alpine head unit
Old Aug 30, 2004 | 11:07 AM
Default Re: CD player needs code after battery reset, any suggestions? (revlimitx04)
word, i gave him a call, he's gonna look.
Old Aug 30, 2004 | 11:23 AM
Ya if you dont have a manual, and he doesnt know the code get an alpine.
I got one and you wont believe the difference, and those back 6x9's can hit!
Old Aug 30, 2004 | 02:28 PM
SH_Mon's Avatar
This happens to me every single time i unplug my battery. However, there's a quick and simple solution to solving this problem.... i went to HONDA and asked them for the code. Just make sure to write down the serial numbers and any other numbers written on your CD player (Yes, you'll have to rip apart the center console and all that stuff) so they can look up your code. Just so i never forgot the number, i just wrote it on my CD player in case it ever happens again. (yea....yea.. that cd player is worthless anyways). Hope that helps.
Old Aug 30, 2004 | 02:29 PM
Behan's Avatar
you can request the radio code from the dealer. Call your dealer and ask them what info they need.
If they say they need to pull the head unit, call another dealer.
Old Aug 30, 2004 | 03:06 PM
bb6h22a's Avatar
Default Re: CD player needs code after battery reset, any suggestions? (Behan)
Call the dealer, give him your vin # and your problem is solved.
The dealer has all these codes listed by vehicle vin - if they tell you otherwise, call another dealer. They may ask you to come down in person (to make sure you're not trying to get a code for a stolen deck) but that's not too great a request.
Old Aug 30, 2004 | 03:17 PM
Monkeyballs's Avatar
i work for an acura dealership, and that vin number thing dont work for us....you gotta pull the radio out and get the serial and model number off of it....
Old Aug 30, 2004 | 03:19 PM
esca's Avatar
alpine
Old Aug 30, 2004 | 03:23 PM
damonk's Avatar
Im curious as to what happens when you use the red key though. Now that i look at it im surprised the guy gave it to me seeing how he was a ***** and tried to screw me in every way. but what happens when you use the red key and dont have the code, cause im almost positive the bastard didnt give me the code.
Old Aug 30, 2004 | 03:30 PM
bb6h22a's Avatar
Default Re: (twopoint5lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twopoint5lude &raquo;</TD></TR><TR><TD CLASS="quote">i work for an acura dealership, and that vin number thing dont work for us....you gotta pull the radio out and get the serial and model number off of it....</TD></TR></TABLE>
Worked for me. I misplaced my radio code card, and simply called the dealer (Hoehn Honda - where I purchased the car), gave them the vin over the phone and had my code then and there. Don't know why you'd have to pull the serial # off the deck as the radio codes are assigned to the vehicle's vin #.
( I even had my org. deck replaced under warranty, and the service dept. had both radio codes in their records as they're assigned to the vehicle.)
Old Aug 30, 2004 | 03:32 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">get an alpine.</TD></TR></TABLE>
Which model Apline deck? My oem cd player is dead and I'm wondering which model you'd reccomend - I don't want anything fancy, just a simple cd player. Also, are there any precautions/problems w/ using aftermarket decks and the 'acoustic feedback system'?
Modified by bb6h22a at 5:02 PM 8/30/2004
Old Aug 30, 2004 | 11:10 PM
Default Re: CD player needs code after battery reset, any suggestions? (bb6h22a)
nope, plug a new deck n and your good to go, alse the feedback system is, is an amplified factory system. I recommend the Alpine 9807, its alittle pricey tho, any alpine deck is good, dont under pay for a deck tho, basically a factory deck is 300+ dollars, anything under that price it aint worth the quality. Stick with name brands like Alpine. stay away from Sony xplod, they explode.
you get what you pay for in audio.
by the way my stock head unit started skipping on all cds and eventually quit working, they are pos.. dunno why Honda went to all the trouble to code a pos, I dont know why anyone would even try to steal a stock system.
Old Aug 31, 2004 | 04:52 AM
00LudeLover's Avatar
many times a normal honda dealership will have to pull the radio in order to get the code, but that i only because they have to know the exact model of the head unit in order to pull the code from the honda data base (i was told) If you go to the dealership where the car was originally bought, they will have it on site, and all the need is your VIN.
but seriously, get an aftermarket system. The gen 5's have clarion mini amps powering the back speakers, and they sound a ton better with an aftermarket. Also, the componants come alive with a new head. If you are doing a full system, i really would do a new head first, then subs, then new speakers all around, if you decide you even need them. I found out i dont, they sound really really good with the new head.
Old Aug 31, 2004 | 05:48 AM
breathinez's Avatar
Open your glove box and look all around the inside and outside it to see if the code was stuck on the side somewhere inconspicuous. Mine was and also on my g-friends civic si. It was a little rectangular sticker with the code on it. It comes like that when you buy it new and some people will pull off this sticker and hide the number in the glove box out of plain view. Heck it want hurt to look.
Old Aug 31, 2004 | 05:57 AM
turnofftheradio's Avatar
my code is on a sticker (5 digit) on the left side of the glove box. FYI the red key is used to program our fancy keys to work in your car if you have that feature, the blinking green light that looks like a key... If you put the red key in, you are looking at the possibility of erasing the memory of all your regular keys. Dont use it
Old Aug 31, 2004 | 12:51 PM
Default Re: CD player needs code after battery reset, any suggestions? (turnofftheradio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00LudeLover &raquo;</TD></TR><TR><TD CLASS="quote">
but seriously, get an aftermarket system.</TD></TR></TABLE>
Just use the code as a reason to buy a new head unit, but dont go cheap or it wont last.
Ive payed 100 for a cd player before and it lasted 2-3 months, i payed 350 for my alpine and its working awesomely great for 8 months.
Alpine 9807- also plays mp3 and xm compadable.
If you do a full stereo go Headunit, then 4 speakers, (i recommend eclipse 4 ways, crystal clear) then get a 4chn amp for the speakers, then do subs. Make it sound good before you add bass, then it will sound outstanding. Once you add bass it drowns out the details of bad speakers, but if you have good speakers and bass it sounds very nice.
Old Aug 31, 2004 | 10:30 PM
ambiguous's Avatar
just go to the dealer with the vin and car of course and they can provide the code for you. if it's not the original one from the car, you'll have to pull it out and look at the serial number and the dealer can provide you with the code from that
loizenin
Mar 16, 2007 09:19 PM
slmulkey
Audio / Security / Video
Sep 11, 2005 11:05 PM
ITR#465
Sep 29, 2004 04:07 AM
Crono139
Jul 17, 2003 01:24 PM
Integra97Zeke
May 19, 2002 08:15 AM
