code 9 and 14 need help
Old Aug 26, 2004 | 09:14 AM
1point7db2's Avatar
Default code 9 and 14 need help
I am throwing a code 9 and 14 , ( cyp and IAC ) and would like to know what i should do to fix these problems. I am also running a p72 Ecu witch helped the sputtering and loss of power a little, but i still dont think its as fast as it should be.
Old Aug 26, 2004 | 09:48 AM
98TypeSH's Avatar
Default Re: code 9 and 14 need help (h22rexguy)
here is a link to a question i already answered about the Cylinder Position Sensor.
https://honda-tech.com/zerothread?id=969598
also, are you having trouble idling? Usally an IACV problem will mess ur idle pretty bad. I also know of quite a few ways to check the IACV if you need them.
Old Aug 26, 2004 | 10:08 AM
1point7db2's Avatar
Default Re: code 9 and 14 need help (98TypeSH)
wich wires on the dist. connector are 2 and 4? Colors? the connector has 8 wires.
Also what are some methods of checking my iacv it only idles weird if i hold throttle etween 1400 and 2000 rpm it was worse with the p13 ecu but i put in a p72 and the car is much more driveable and has more power, but still not what it should be.
Old Aug 26, 2004 | 10:11 AM
98TypeSH's Avatar
Pull the distrib connector, the male side, which is connected to the distrib.
Looking directly at it, with the mounting clip facing up, 2 and 4 are located on the right side. Tell me if you need a pic.
Old Aug 26, 2004 | 10:14 AM
1point7db2's Avatar
i think i see what youre sayin but give me a pic to be sure.
Old Aug 26, 2004 | 10:24 AM
98TypeSH's Avatar
Wire colors are solid yellow and solid black.
Meter them, you need between 260-460 ohms.
If you have that, do them one at a time to a ground source, if you get a reading thats bad.
Old Aug 26, 2004 | 04:35 PM
98TypeSH's Avatar
just makin sure u saw this post rex,
Old Aug 26, 2004 | 04:44 PM
Jagan'92's Avatar
You just want him to come back and look at your picture
Why don't you explain a few ways to check the IACV?
guy_from_nerk
12
Jan 13, 2009 07:24 AM
integrar00
Feb 20, 2008 03:27 PM
joshcuhz
Feb 8, 2008 07:14 PM
90crxdxb16
Sep 20, 2006 08:22 PM
