brake light problem
Old Aug 28, 2004 | 03:29 PM
esca's Avatar
Default brake light problem
does anyone have ap roblem with their brake light indicator? mine seems to go on during random times and it stays off at other times. any insight?
thanks
Old Aug 28, 2004 | 04:40 PM
prelude2300's Avatar
Default Re: brake light problem (esca)
is it the turn indicator or the brake lamps??
Brake:
if its your brake lights check out you r brake pedal switch some times those act up andcan be replaced
turn indicator:
try looking at the the switch on the steering wheel, move it around a little bit and see if you can get it to act up, most of the time they'll get a bacd connection, if it acts up when you move it around, that's your problem, replace the switch and you should be good, if not check out your flasher relay, some times those have bad contacts, and go out..
Old Aug 28, 2004 | 06:00 PM
esca's Avatar
yeah..e verythign seems to work.. it just comes on randomly during driving..
i checked teh brake lights, and the turn siginals and even the headlights.. also reverse lights too.. maybe some defect?
oh well.. as long as its not a big deal
Old Aug 28, 2004 | 06:24 PM
SuperSlow's Avatar
mine did the same for a while, and the light on the dash was on when there were no probs. It went away a while ago, and I am not sure why. I am guessing bad connections as well.
Old Aug 28, 2004 | 06:39 PM
esca's Avatar
Default Re: brake light problem (SuperSlow)
hrm.. alright.. thanks
Old Aug 29, 2004 | 10:10 PM
revlimitx04's Avatar
Esca i have the same problem, the light is on somtimes, and off... Im leaning towards a bad sensor, dunno tho, but having a red light on dash is annoying.
Old Aug 30, 2004 | 06:50 AM
kellyk75's Avatar
Another typical prob for the 5th gen. It is a touchy low fluid level sensor..... we all have it. When it is cold, the brake fluid contracts and when you hit the brakes, the reservoir level lowers.
Just top the level of the brake fluid off to the full level. If it is just a bit lower, you will have that problem.
Old Aug 30, 2004 | 08:45 AM
RHD_BB4T's Avatar
Default Re: brake light problem (kellyk75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kellyk75 &raquo;</TD></TR><TR><TD CLASS="quote">Just top the level of the brake fluid off to the full level. If it is just a bit lower, you will have that problem.</TD></TR></TABLE>
Old Aug 30, 2004 | 11:03 AM
Default Re: brake light problem (RHD_BB4T)
awesome.
Old Aug 30, 2004 | 11:16 AM
esca's Avatar
what if you have a 4th gen.. same thing?
Old Aug 30, 2004 | 01:31 PM
yes esca, just up that fluid level.
Xzay01
Lighting
Jun 14, 2013 08:53 AM
EGKevin209
Jun 22, 2010 12:41 PM
kornkid21792
Jan 21, 2010 03:27 AM
neogenesis2004
Mar 3, 2009 04:21 PM
Captain JDM
Oct 23, 2006 11:35 AM
