Code 17- Help!!
Old Aug 27, 2004 | 11:33 AM
shabasoft's Avatar
Default Code 17- Help!!
I have done a check for my "check engine light" and recieved a code 17.
I know this is soemthing to do with my speed sensor.. does anyone know what the exact problem is and how to fix it??
thanks
Old Aug 27, 2004 | 11:45 AM
CHK4TIX's Avatar
Default Re: Code 17- Help!! (shabasoft)
check to see if its unplugged first, then check to see if it is loose and broken. I went through a few of them, because the side mounting bracket has a tendency to break. also be aware that there are 2 different versions of the vss
heres a pic for the hell of it
Modified by CHK4TIX at 3:10 PM 8/27/2004
Old Aug 27, 2004 | 12:03 PM
kellyk75's Avatar
Default Re: Code 17- Help!! (CHK4TIX)
^^ Gee..... you were no help.
JK
Old Aug 27, 2004 | 04:28 PM
Memo6453's Avatar
do u have a catalytic on the car? if not maybe u need a simulator to keep that check light off...but if u do have a CAT and its on reset it by taking the negative off the batery terminal, wait a minute then put it back on...u gotta re-due ur radio stations but it should reset it, but if not one more time, then ur screwed i dunn0
Old Aug 28, 2004 | 07:26 AM
shabasoft's Avatar
where are the parts in that pic above?
bma1818
Apr 19, 2006 09:55 PM
IgniteTeg
Aug 8, 2002 09:26 AM
