Which distributor cap on jdm h22??
Old Aug 26, 2004 | 09:28 PM
h22Hatchy's Avatar
Default Which distributor cap on jdm h22??
Alright guys I have a jdm h22a head on my usdm h22a4 block in my eg hb. I Have msd in my car right now, but I am wonderng which msd distributor cap I am supposed to use. I bought a regular prelude one and it didnt fit. I tried like 2 other ones off my friends cars and they didn't fit. Right now I am using one off of a 99 civic si. Two of the 3 holes line up so its on and my car is running but its still not the right cap. Anyone know which cap I need? Thanks.
Old Aug 26, 2004 | 09:48 PM
MackDad's Avatar
Default Re: Which distributor cap on jdm h22?? (h22Hatchy)
96+ Integra GS-R cap...Rotor is a Prelude
Old Aug 26, 2004 | 09:53 PM
Quick99Si's Avatar
I believe that a 99-00 Si cap also worked... not 100% sure though.
Adi
Old Aug 26, 2004 | 10:44 PM
PreludeRacer023's Avatar
Default Re: Which distributor cap on jdm h22?? (Quick99Si)
the JDM one is internal coil which is where your problems are coming in, youll need to run the stock distributor or convert the internal coil to external
Old Aug 27, 2004 | 01:29 AM
H23AHybridEG's Avatar
I am 100% positive that you can use a cap from a 1992-1995 Civic Si and a rotor from a 1992-2001 Prelude. I just did this myself
Old Aug 27, 2004 | 01:40 AM
Ransom's Avatar
Default Re: Which distributor cap on jdm h22?? (H23AHybridEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23AHybridEG &raquo;</TD></TR><TR><TD CLASS="quote">I am 100% positive that you can use a cap from a 1992-1995 Civic Si and a rotor from a 1992-2001 Prelude. I just did this myself </TD></TR></TABLE>
Any 92-95 civic cap will work
Old Aug 27, 2004 | 03:43 AM
Default Re: Which distributor cap on jdm h22?? (LudeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeSH &raquo;</TD></TR><TR><TD CLASS="quote">
Any 92-95 civic cap will work </TD></TR></TABLE>
Hehehe! I thought so, too, but I didn't want to provide him with information I wasn't 100% sure on
Old Aug 27, 2004 | 04:43 AM
SearchBeforeUPost!'s Avatar
90-91 accord or 92-95 civic cap.
Old Aug 27, 2004 | 08:21 AM
93H22ACX's Avatar
Default Re: Which distributor cap on jdm h22?? (SearchBeforeUPost!)
for JDM H22 distributor you can use 90-93 integra distributor cap
Old Aug 27, 2004 | 08:41 AM
h22Hatchy's Avatar
So I can use a 96 + gsr, 92-95 civic, 90-91 accord, or a 90-93 integra, and the rotor is from a 92-2001 prelude. Alright cool, Thanks guys. I will try one of these.
Ohh and yaa I heard about them being internal coil and what not, But I have msd now and an external msd blaster coil. Thanks guys.
Old Aug 27, 2004 | 10:05 AM
Ransom's Avatar
if u have an external coil use usdm h22 cap
Old Aug 28, 2004 | 06:55 AM
2lude4u's Avatar
If you're external coil the F22 cap should work as well. I used an F22 cap to convert my H22 distributor to external coil. If you plan on trying this out, contact me there was a timing issue that can be solved by rotating the plug wires 90 degrees or swapping distributor internals. I ran into this when I swapped an H22 into my F22 prelude.
Old Aug 28, 2004 | 09:13 PM
h22Hatchy's Avatar
Default Re: Which distributor cap on jdm h22?? (2lude4u)
Alright thatnks for the info guys. I'll let you know.
drbenne
May 25, 2009 06:26 AM
Bird333
Nov 4, 2004 09:07 AM
snake679
Jun 23, 2003 10:23 PM
rick_spiff
May 14, 2003 05:34 PM
servion
Jun 20, 2002 08:59 AM
