DC headers?
Old Aug 25, 2004 | 08:31 AM
tobbe83's Avatar
Default DC headers?
which header is the best 4-2-1 eller 4-1 for my prleude -93 vtec?
Old Aug 25, 2004 | 08:39 AM
SuperSlow's Avatar
Default Re: DC headers? (tobbe83)
SMSP.
Old Aug 25, 2004 | 10:51 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: DC headers? (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">SMSP.</TD></TR></TABLE>
you're an internet racer dick, not everybody wants to buy a super expensive header that you need to notch your crossmember for and/or a header that'll crack because no flex pipe is included. your post is useless.
the 4-2-1 is better i think because the h22 is not a high revving motor and is not designed for peaky horsepower (which the 4-1 emphasizes). the 4-2-1 is better because it'll give you more mid range than the 4-1 will give you top end.
Old Aug 25, 2004 | 01:44 PM
Behan's Avatar
Default Re: DC headers? (PreIudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">
you're an internet racer dick, not everybody wants to buy a super expensive header that you need to notch your crossmember for and/or a header that'll crack because no flex pipe is included. </TD></TR></TABLE>
The SMSP does not require notching of the crossmember and uses a donut gasket instead of a flex pipe. Due to the negative flow charateristics of flex pipes.
Trust me the SMSP will not crack, i had a nasty encounter with a speed bump and the header did NOT crack.
Just wanted to clear that up.
BTW, 4-2-1 for h22 = , IMO
Old Aug 25, 2004 | 02:04 PM
98TypeSH's Avatar
Default Re: DC headers? (Behan)
Also, 4-2-1's provide more clearance because its not one solid peice. If you do decide to get a DC, i would suggest you mod the collector to a 2.5 inch or your efforts are FUTILE! Or just get a prospeed,smsp,hytech so on and so forth .
Old Aug 27, 2004 | 12:35 AM
jdmh22eg's Avatar
Default Re: DC headers? (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Or just get a prospeed,smsp,hytech so on and so forth</TD></TR></TABLE>
honda_coupe
26
Apr 27, 2007 02:24 PM
integracura
Apr 20, 2006 07:03 PM
2zzgeMonster
Oct 11, 2005 09:36 PM
Jaysun
Mar 6, 2005 12:01 PM
Synergy001
13
Sep 3, 2003 11:13 AM
