replacing pistons
Old Sep 23, 2004 | 05:37 PM
hOndafienD 04's Avatar
Default replacing pistons
thinking of going with h22 pistons in my h23...now would i be able to do this with the motor in the car and just threw the bottom of the motor, w/o ripping out the head, or is that impossible?
Old Sep 23, 2004 | 05:56 PM
speedracer9k's Avatar
are you going to leave the crank in, or are you going to take it out. If you leave it in you wouold have to take the head off and slide the piston and rod down the cylinder walls. Then tourqe down the rod bolts around the crank. This would be the most ideal way to do it. You just need to get a piston ring compressor.
Old Sep 23, 2004 | 06:07 PM
damn man no easy way around this...**** lol....umm thanx....when you goin to uti?? and what campous...i might be going after high chool :-D
Old Sep 26, 2004 | 03:02 PM
i start january 10th. Its the campus in Avondale, AZ.
Old Sep 26, 2004 | 03:28 PM
flip1199's Avatar
Default Re: (speedracer9k)
i'd get the block honed, so your gonna need to take the block out..
Old Sep 26, 2004 | 03:35 PM
man **** all motor....im going boost...isnt that what h23 is best known for????!!!!
Old Sep 27, 2004 | 09:00 AM
93H22ACX's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">man **** all motor....im going boost...isnt that what h23 is best known for????!!!!</TD></TR></TABLE>
no...weak ringlands like the h22...
you could boost 6-7 psi
MadCityLude
Jul 14, 2006 04:10 PM
CivicVX94
Feb 6, 2006 11:35 PM
tgh22a
Nov 4, 2005 07:49 AM
v-6 hatch
Mar 1, 2005 08:09 PM
Fly1865
Jul 24, 2004 10:52 AM
