VSS problemo
Old Sep 24, 2004 | 08:24 AM
supermancory's Avatar
Default VSS problemo
Ok folks, i'm having some freeaky problems with my VSS- as in, it shut off a while back so i swapped it with another one and for the last two days, i've had about 95 miles of knowing how fast i was going and wonderful, wonderful VTEC(gotta love VTEC). anywho, it just sort of randomly comes on and shuts off and i was wondering if anyone had any ideas... any input would be appriciated
Old Sep 24, 2004 | 09:27 AM
Jason kiDD's Avatar
Default Re: VSS problemo (supermancory)
Lude Vss's are only held on by one bolt which sux. So if that bolt is not tight then the actual sensor can lose contact with the gear. Make sure you tighten down the bolt but do no break it..
Old Sep 24, 2004 | 10:04 AM
esca's Avatar
might wanan check your wiring too.. shorts can happen when exposed wire touches metal for a split second
Old Sep 24, 2004 | 10:05 AM
Default Re: VSS problemo (Jason kiDD)
yeah, i was thinking of trying to tighen it down a little more, but like you said, i don't want to break anything (specifically that oddly shaped bolt of the bracket that holds it on)
brendon.richey
Feb 25, 2013 04:16 PM
telekineticz
Aug 10, 2009 02:08 PM
egstockboosted
Nov 28, 2007 08:58 PM
Pockets
Suspension & Brakes
Oct 3, 2007 04:29 PM
Ragecloak
Feb 25, 2005 07:54 AM
