Reverse not working!!!
Old Sep 27, 2004 | 05:22 PM
RemerLex11's Avatar
Default Reverse not working!!!
I did something very stupid....i was racing and was at the redline in 4th gear, and instead of shifting into 5th i went into 3rd........and u know the rest. went back into neutral immidiately and now reverse doesn't work. the tranny still shifts fine but i can't get it into reverse. what am i gonna have to do to fix this one??
Old Sep 27, 2004 | 10:10 PM
americ_ian's Avatar
Default Re: Reverse not working!!! (mafoo_2005)
yes, same thing happened to me...my reverse got jammed! i forced it back in after a couple weeks, but my gearbox was never the same...it happend a couple more times when my friend was driving and he missed a gear...i lost reverse, got it to work then lost 5th!!! then it came right, but then 5th gear syncho blew out...and after a while, my whole box started playing up...and sumtimes i cant get into any gear at all.... and it whines wenever it is in gear driving, or wen the clutch is out
i jus purchased a new g-box...so wen i rip my old one apart il do sum investigating hehe
but if anyone know why the syncho hubs lock up and get jammed id like to know
Old Sep 27, 2004 | 10:42 PM
PrettyLude's Avatar
the prelude transmission always had that problem with the reverse and 5th gearset,
my guess is that u bent a fork, i did, 3 times in fact
Old Sep 28, 2004 | 02:00 PM
h22 civic's Avatar
Default Re: (PrettyLude)
how much$ are the shift forks?
Old Sep 28, 2004 | 05:37 PM
PrettyLude's Avatar
shift forks at not much, check at http://www.hondaautomotiveparts.com
Old Sep 28, 2004 | 08:26 PM
UA6 BALLER STATUS's Avatar
Same exact **** happened to me a year ago, I took it back to the dealership where I got it from and they fix it and they said it would have costed 1600 if i didn't have a warranty. thats some BS right there
Old Sep 29, 2004 | 10:34 AM
PrettyLude's Avatar
same here, if the warranty would not have covered it, it was gonna be 1200 to fix it
Old Sep 29, 2004 | 12:34 PM
93vtec ATL's Avatar
Default Here's how i fixed it
I had nearly the same thing happen to me. Here's how I fixed it.
With the car parked, I applied pressure on the lever to try and put it in reverse gear. While I did this, I slowly let off the clutch, and gave it just enough gas to prevent it from stalling (I kept it around 1k RPM).
With a bit of pressure, it eventually popped right into place. The only problem was, I was then stuck in reverse. I drove a small distance in reverse (I don't know if this helped or not), and then repeated hte above process to get out of gear.
This happenned to me over the summer, and happened once more about a week or so later. Since then, everything has been normal.
I got this method form another board when my car was having the problem, and it seems as though it has worked for other people too.
I know its unorthodox or whatever, but its worth a shot at beating a $1200 bill, right?
(Oh yeah, this took me a few tries to get it to work, but it hasn't failed me yet.. don't be afraid to give it a little force.. if you let the clutch out with no gas, and the car stalls (without going into gear) you know you are pushing just about hard enough.
good luck
Old Sep 29, 2004 | 04:07 PM
RemerLex11's Avatar
Default Re: Here's how i fixed it (93vtec ATL)
i tried your method and i would get it about half way into reverse and let off the clutch a bit and give it a little gas and it wasnt moving and i could hear the gears grinding a little bit. I tried it a few times, and it just didnt wanna get in there. How many times did it take you? and was your situation different somehow because since i couldnt totally get it into gear, it wouldnt stall when i totally released the clutch.
Old Sep 29, 2004 | 05:17 PM
93vtec ATL's Avatar
Default Re: Here's how i fixed it (mafoo_2005)
I couldn't get into gear at all either. all other gears worked fine, but when i moved the shifter to the right, it wouldn't move down at all.
When I was trying it, I did it about five times, and I couldn't get it.. I actually gave up and went back inside. I tried it again later a few more times and it worked.
In order to get it to stall, i had to REALLY push on it as i released the clutch very slowly. When you let your clutch out, do your rpms fluctuate at all? The first thing I noticed was that without any gas, I would lose about 300RPM with a bit of pressure. If you tice any change at all, then I would guess its a similar problem.
I just continued to push it and eventaully I got it to stall. If you reach this point and give it just a bit of gas, instead of stalling, it should get right into gear. The fact that your gears are grinding tells me that you are making contact and your gear is just stuck.
When it finally worked for me, I applied firm pressure very slowly, and let the clutch out VERY slowly again. I feathered the gas as the revs began to drop and eventually it kicked in with a bit of a grind.
I'm afraid I haven't added very much information, but the way it sounds, your symptoms are very similar to mine. Perfecft gearbox operation with no access to reverse. The grind is reassuring as it means you are at least making making contact between the gears.
I'm no mechanic, but it seems to me as though the reverse gear is locked in place, and just needs to be broken free. I think it is in a position where the gear tooth is obstructing the two gears from meshing, and all it needs is a little force to force it to spin to a position where the other gear can force it to move.
Again, this is just speculation, but the only thing I know for a fact is that this worked for me.
Good luck
Old Oct 1, 2004 | 06:53 PM
RemerLex11's Avatar
crap it didnt work, and my friend had this prob in is gsr and your solution worked for him but he tried it on my car and it didnt work. i got the gear to grind really loudly but it just wont pop in. im afraid to think how much this is gonna cost me.......
Old Oct 1, 2004 | 09:12 PM
PrettyLude's Avatar
bent shift forks
Old Oct 1, 2004 | 11:13 PM
951dc5's Avatar
My Gosh..same thing happened to me. Wut happen was, i was on third gear running normal and then pop in second gear to speed pass this slow car without any grindin until i got to the parking lot, my prelude couldn't turn into a narrow spot so i need to reverse..then WHAT!!? i couldnt pop in reverse. It was so hard to even force it in. I had to push it back. I went home and parked, messed with the slave cylinder and then my padal falls to the floor..i try bleedin it but nothing! Anyone knows the situation??
Old Oct 2, 2004 | 06:20 PM
RemerLex11's Avatar
Default Re: Here's how i fixed it (Prelude951)
well i think i fixed my prob at least temporarily.......my clutch fluid was kinda low so i put more in and now reverse works. it still feels kinda stiff especially getting out of reverse but itll work for now.
Old Oct 2, 2004 | 06:32 PM
Wiseguy619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">bent shift forks</TD></TR></TABLE>
Yup.
Old Oct 15, 2004 | 01:57 PM
951dc5's Avatar
DOES ANYONE HAVE A PICTURE OF A FOLK??
Old Oct 15, 2004 | 01:59 PM
951dc5's Avatar
hey where did you pour your fluid in your clutch?? cuz i dont really know about the h22 basic tranny
Old Oct 15, 2004 | 10:36 PM
PrettyLude's Avatar
u can pour it in the big 17 mm nut on the side, or you can pour it in the vss sensor hole.
Old Oct 16, 2004 | 04:19 PM
h22 civic's Avatar
how could ya tell if the shift fork is bent when it is out of the tranny
Old Oct 17, 2004 | 06:06 PM
951dc5's Avatar
Where is this "vss sensor hole??" Located?
Old Oct 17, 2004 | 06:09 PM
951dc5's Avatar
Default Re: Here's how i fixed it (h22 civic)
Is there a way to replace a shift fork since that's the problem??
Old Oct 17, 2004 | 08:33 PM
PrettyLude's Avatar
to change the fork you would have to tear down the tranny as far as the vss sensor hole, its in the back with a harness coming out of it
Old Oct 17, 2004 | 09:52 PM
951dc5's Avatar
Damn that's alot of works, i think i might as sell this prelude off my friend when he offered me 1500.
d16efsedan
16
Nov 29, 2016 09:35 PM
dornon13
Dec 24, 2007 10:21 AM
e.nergie
Aug 18, 2007 11:50 AM
snzh22
Dec 9, 2006 08:20 PM
eric416
Jun 23, 2006 02:10 PM
