DSM H22 Setup?
Old Sep 24, 2004 | 10:30 AM
supermancory's Avatar
Default DSM H22 Setup?
I forgot where i had read it, but i saw somewhere that it was possible to use the turbo manifold from a 1g- 2g eclipse on an H22 cause the bolt patterns matched up. Does anyone know if this is Really true or not and if there are any Fitment/ space issues? Also, what kind of numbers would that put down?
Old Sep 24, 2004 | 10:32 AM
chrysler kid's Avatar
Default Re: DSM H22 Setup? (supermancory)
it wasnt a direct fit, the bolt holes didnt line up so he drilled them out and made new holes on the manifold. you would need to put the h22 gaskett agains the dsm manifold and then drill out new holes.
Old Sep 24, 2004 | 10:56 AM
Default Re: DSM H22 Setup? (chrysler kid)
k, but how close is "close"
also, what about fitment issues in regards to the turbo?
Old Sep 24, 2004 | 11:02 AM
red92si's Avatar
I dont even think it will fit up to the H22 head at all. I know for certain though that with slight bolt hole modification the DSM manifold will fit on an H23 or F22 head with no problem.
Old Sep 24, 2004 | 11:49 AM
H22Si's Avatar
Default Re: (red92si)
i mated a buddys 1st gen manifold up to my h22 when the motor was out. i suppose it can be done and work ok, but i personally didn't like what i saw. the ports in the manifold would need to be worked excessively to provide a smooth transition. even then, it wouldn't look pretty. although, the bolt holes can deffinately be slotted to fit correctly.
i wouldn't even bother with trying it, let alone running with it.
Old Sep 24, 2004 | 04:23 PM
sonnyboi612's Avatar
http://www.xratedcc.com/forums...=1214
Old Oct 4, 2004 | 11:11 AM
Drag-Accord's Avatar
Default Re: DSM H22 Setup? (sonnyboi612)
yup! that's me. i did it. and it works.
works like **** but hey it's boost.
1st person to ever successfully use a FULL dsm setup on an h22.
umair
Dec 25, 2014 08:52 AM
rsdc81
Dec 19, 2007 12:06 AM
beak
Feb 21, 2006 09:02 PM
jojowasha
Mar 21, 2005 07:35 PM
