Knocking
Old Sep 22, 2004 | 02:22 PM
jaydemlude's Avatar
Default Knocking
i just smogged my car today and it didnt pass..i changed everything back to stock..but the smog tech said i had some knocking..but i dont really know what that is.. can anyone help me out?
Old Sep 22, 2004 | 03:11 PM
red92si's Avatar
rod knock or ping/detonation knock?
Check and reset your ignition timing back to 15 +/- 2.
Old Sep 22, 2004 | 07:24 PM
00LudeLover's Avatar
Default Re: (red92si)
it is knocking because your car, i am assuming, was tuned with your aftermarket parts on, because you are running all stock it is knocking and will hurt your engine. If you are planning on putting your aftermarket parts back on since you passed smog, it will probably stop knocking, but put them back on soon, because knocking is bad for your car.
knocking is predetonation in your engine.
Old Sep 22, 2004 | 09:46 PM
jaydemlude's Avatar
Default Re: (00LudeLover)
the only mods i had was i/h/e..how do i reset the ignition timing?
Old Sep 22, 2004 | 10:32 PM
red92si's Avatar
If your car is OBD-I then all you need to do is hook up a timing light to your engine and read the timing through the access port in the block. Then just adjust the distributor until the timing light reads within 2° of 15° at idle.
perry9251
Feb 21, 2018 07:58 PM
beocop
Dec 15, 2016 09:05 AM
iponnet
Mar 16, 2011 05:33 PM
methos713
Jul 28, 2008 08:51 AM
them8te
May 5, 2003 08:08 AM
